Re: AAR p/s pump.
[Re: fastmark]
#2330692
07/03/17 02:11 PM
07/03/17 02:11 PM
Posts: 322 MERRILLVILLE, INDIANA
sunroof446
Mine has a federal pump with a solid pulley, if that helps. Sounds like you have the wrong pump and/or pulley. You may have a BB pulley. The SB with the Saginaw pump has a different offset. This one doesn't have a solid pulley, I have no clue where the customer got this pump from, definitely wrong. Just trying to figure out what I need. Thanks.
Re: AAR p/s pump.
[Re: Alaskan_TA]
#2330735
07/03/17 03:55 PM
07/03/17 03:55 PM
sunroof446
The pulley is 7 inches in diameter. casting number on pump is 2537955. Customer supplied his own parts. He started out with the wrong crank pulley, I have the right crank and w/p pulley on now. definitely something up with the pump, pulley, or both.
Re: AAR p/s pump.
[Re: NANKET]
#2331031
07/03/17 10:03 PM
07/03/17 10:03 PM
Posts: 2,373 Banana Republic
FM3AAR
Banana Republic
Here's the original pump on my AAR.
“You’ll own nothing” — And “you’ll be happy about it.” K. Schwab
Re: AAR p/s pump.
[Re: FM3AAR]
#2331078
07/03/17 11:27 PM
07/03/17 11:27 PM
sunroof446
Here's the original pump on my AAR. would you happen to have the casting number that's on the bottom of the pump? and possibly a photo looking straight down from the top. I would like to see the distance of the pulley to the pump body. Thanks.
Re: AAR p/s pump.
[Re: sunroof446]
#2331192
07/04/17 08:12 AM
07/04/17 08:12 AM
sunroof446
Here's the original pump on my AAR. would you happen to have the casting number that's on the bottom of the pump? and possibly a photo looking straight down from the top. I would like to see the distance of the pulley to the pump body. Thanks. Thanks, I have the same casting number, I must have the wrong pulley on the pump or crank, My water pump lines up fine so I think I can eliminate the crank pulley, looks like your p/s pulley sits closer in.
Re: AAR p/s pump.
[Re: Alaskan_TA]
#2331612
07/04/17 10:34 PM
07/04/17 10:34 PM
sunroof446
I dug out the two I had. One is from a car without AC & the other had AC.
The pulleys are different on mine.
The non AC version has curved spokes.
The AC version has flatter spokes.
Rough guess without measuring is close to a 1/2 offset difference between the two.
If needed I can put them in the parts washer for a cleanup & get photos. The pulley on mine is sitting about a half inch to far forward, looks like I have an a/c pulley on the pump from your info. Thanks for checking.
Re: AAR p/s pump.
[Re: sunroof446]
#2331732
07/05/17 01:44 AM
07/05/17 01:44 AM
FM3AAR
Banana Republic
Here's a pic of my AAR pulley after bead blasting. I was unable to make out the numbers where I have the X's.
Re: AAR p/s pump.
[Re: sunroof446]
#2331757
07/05/17 04:49 AM
07/05/17 04:49 AM
Posts: 566 WA
tman
WA
Hmm, maybe reverse the pulley? Disregard.
Re: AAR p/s pump.
[Re: 6bblgt]
#2331764
07/05/17 05:33 AM
07/05/17 05:33 AM
Posts: 17,521 Las Vegas, NV
6bblgt
Las Vegas, NV
HOLLANDER shows: AAR & T/A FEDERAL pump w/reservoir (NO pulley) #3004 799 the same as 1969-'72 C-body VS. E-bodies FEDERAL pump w/reservoir (NO pulley) #3004 800 the same as 1969-'72 B-body and others & I lightened FM3AAR's pic
Re: AAR p/s pump.
[Re: 6bblgt]
#2332289
07/06/17 01:25 AM
07/06/17 01:25 AM
Posts: 1,811 North Dakota
Azzkikrcuda
North Dakota
If you run out of ideas you can put the pulley in a press and rebend it to the depth you need to line up. I have done this to quite a few over the years. Then install it on the pump, clamp the pump in a vise and spin it to check pulley run out. If you need to adjust it you can just bend it by hand. The 3 spoke pulleys are very easy to bend.
The only Carbs I care about are under the hood!
