Re: Lexan install
[Re: Quicktree]
#232458
02/22/09 11:32 AM
02/22/09 11:32 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
tony,i used to use alot of plexi and lexan when i was in the sign buisiness and there were special drill bits that had a long taper to them specialy for drilling plastics,but i cant seem to find a supplier,what do you use? also what are you using for gasket mat.?
Re: Lexan install
[Re: bonefish]
#232459
02/22/09 11:34 AM
02/22/09 11:34 AM
Quicktree
well it's only 1/8" thick so I just use a regular bit.
Re: Lexan install
[Re: smokinwoody]
#232463
02/22/09 01:16 PM
02/22/09 01:16 PM
Posts: 1,664 North Sweden
RT540
North Sweden
Tony, your car looks very nice ![](/ubbthreads/images/graemlins/beer.gif) I cut my lexan in a sheet metal cutter ( which can cut 2m long sheets). If you want real nice edges, you can sand papper the edges with a long board, like 3M.
Re: Lexan install
[Re: RT540]
#232464
02/22/09 01:51 PM
02/22/09 01:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Very nice Tony... super clean lookin ![](/ubbthreads/images/graemlins/thumbs.gif) If you want a nice edge on the lexan after you cut it, sand with a block then hit it with a propane torch, it'll make it clear again ![](/ubbthreads/images/graemlins/wave.gif)
Re: Lexan install
[Re: MR_P_BODY]
#232465
02/22/09 04:10 PM
02/22/09 04:10 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
Did you ever work for me?....you tend to know alot of tricks....LOL
Re: Lexan install
[Re: Chassisman]
#232466
02/22/09 04:17 PM
02/22/09 04:17 PM
MR_P_BODY
LOL, I dont think I ever worked out on that coast, just lots of years for Chrysler in engineering doing all sorts of testing... and making some show parts/cars ![](/ubbthreads/images/graemlins/wave.gif)
Re: Lexan install
[Re: MR_P_BODY]
#232467
02/22/09 04:58 PM
02/22/09 04:58 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
More tips on this trick ???
Re: Lexan install
[Re: VernMotor]
#232469
02/22/09 05:03 PM
02/22/09 05:03 PM
MR_P_BODY
Jamie, its super easy, after sanding to get the edge nice and straight you pass the torch across it just so that it clears up(its slightly melting it) plus it puts a minor radius on both edges... just looks alot nicer and gives it a finished look. Test on a piece of scrap to see how much time you need to spend on it EDIT If you hold the torch square to the edge it will radius both sides at once ![](/ubbthreads/images/graemlins/wave.gif)
Re: Lexan install
[Re: MR_P_BODY]
#232474
02/22/09 08:40 PM
02/22/09 08:40 PM
Quicktree
I dont know Tony... I like it. What you dont like the glossy black?
it's kind of bright against the yellow. I don't like the black go wing either.
