28 inch tall front runner for a heavy car 3600lbs? #2322244
06/16/17 05:29 PM
06/16/17 05:29 PM
Dirty Dena, Maryland
dodge turbo Offline OP
Anyone have an expirance
Also its a drag radial vehicle. Is it ok to run a bias ply front runner?
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: 28 inch tall front runner for a heavy car 3600lbs? [Re: dodge turbo] #2322311
06/16/17 07:54 PM
06/16/17 07:54 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
I have a Hancook front tire on my Cuda, 15"x3.5" wheels, its 3800lbs, the tire is a regular radial, steers and handles much better than the MT bias ply it has before these. My car is a street/strip car, mid-10.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: 28 inch tall front runner for a heavy car 3600lbs? [Re: dodge turbo] #2322351
06/16/17 09:16 PM
06/16/17 09:16 PM
Locomotion Offline
Locomotion  Offline
I run 28" Hoosier bias ply fronts on my Dart Sport at 3,550 + lbs on a regular basis and have run it at 3,700 + lbs many times. Hoosier radial slicks on the back.
Re: 28 inch tall front runner for a heavy car 3600lbs? [Re: dodge turbo] #2322422
06/17/17 12:18 AM
06/17/17 12:18 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I run Hancook or Kumho on my satellite , 185/80R15 . A mate runs a taller MT radial front runner at 3900lbs .
No mix and match radial/crossply front to rear
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 28 inch tall front runner for a heavy car 3600lbs? [Re: dodge turbo] #2322437
06/17/17 12:40 AM
06/17/17 12:40 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Just make sure they are speed rated, I ran Volkswagen tires on my grudge truck back in the day, I will never do that again..........
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: 28 inch tall front runner for a heavy car 3600lbs? [Re: dodge turbo] #2322635
06/17/17 02:26 PM
06/17/17 02:26 PM
Yea thats what im worried about is the speed rating
I have a regular radial street tire (cooper) and its only rated
To 110
Re: 28 inch tall front runner for a heavy car 3600lbs? [Re: dodge turbo] #2322727
06/17/17 07:33 PM
06/17/17 07:33 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I run a M/T 315/60 Drag Radial on the back and M/T ET bias ply front runners and mine handles just fine. Have been running this combo for 3 years.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 28 inch tall front runner for a heavy car 3600lbs? [Re: dodge turbo] #2322735
06/17/17 08:05 PM
06/17/17 08:05 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
I asked almost the same question on y/b a short while ago. M/T Sportsman pro was suggested a few times.
Photobucket sucks
Re: 28 inch tall front runner for a heavy car 3600lbs? [Re: dodge turbo] #2322775
06/17/17 09:33 PM
06/17/17 09:33 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Used that one and the Moroso weighing almost 3900 lbs.MPH was 145. smoke
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 28 inch tall front runner for a heavy car 3600lbs? [Re: dodge turbo] #2323315
06/18/17 10:42 PM
06/18/17 10:42 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
205/70-15 Ecopia EP422 plus on a 15x6
@3,950
But i street drive as well
Re: 28 inch tall front runner for a heavy car 3600lbs? [Re: dodge turbo] #2323493
06/19/17 10:15 AM
06/19/17 10:15 AM
an8sec70cuda Offline
I use M/T Sportsman fronts that are 28" tall w/ drag radials out back. My car is about 3900 lbs. It handles fine at the track...on the street is where the bias ply fronts suck. They follow ruts real bad.
I'd recommend the M/T Sportsman SR radial they have now that is 28" tall.
The M/T 6678
http://www.jegs.com/i/Mickey-Thompson/672/6678/10002/-1
It's what I'll be getting for the front of mine next.
Don't be concerned w/ the speed rating for a street/strip vehicle. That's for sustained speeds, not short bursts like our cars see. There are tons of FAST cars running 165R15 VW tires for years w/ no issues.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 28 inch tall front runner for a heavy car 3600lbs? [Re: an8sec70cuda] #2323635
06/19/17 03:10 PM
06/19/17 03:10 PM
mn.
taxidermy man Offline
mn.
^^^ Didn't know the SR came in a tall front now...Good to know.
Re: 28 inch tall front runner for a heavy car 3600lbs? [Re: dodge turbo] #2323751
06/19/17 06:49 PM
06/19/17 06:49 PM
central il.
second 70 Offline
second 70  Offline
central il.
I agree with Chip I just drove my cuda on a 80 mile trip with the et bias and thought I was going to have to stop and retighten the fenders. Yes they were on new rims and balanced. Awful!
I have a set of bfg radial ta's that I used when I was breaking in the new Dana and you could drive it with one finger.
Re: 28 inch tall front runner for a heavy car 3600lbs? [Re: dodge turbo] #2323990
06/20/17 02:19 AM
06/20/17 02:19 AM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
Run the Hoosier 28" skinny and the 10.5x30 radial slick in the back on my sled. 3800 without me and over 4000 once I get in. 130 on the top is nice and stable. Look good as well.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
