28 inch tall front runner for a heavy car 3600lbs?
#2322244
06/16/17 05:29 PM
06/16/17 05:29 PM
Posts: 468 Dirty Dena, Maryland
dodge turbo
Anyone have an expirance
Also its a drag radial vehicle. Is it ok to run a bias ply front runner?
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: 28 inch tall front runner for a heavy car 3600lbs?
[Re: dodge turbo]
#2322311
06/16/17 07:54 PM
06/16/17 07:54 PM
Posts: 860 lancaster,california
johnnycuda
I have a Hancook front tire on my Cuda, 15"x3.5" wheels, its 3800lbs, the tire is a regular radial, steers and handles much better than the MT bias ply it has before these. My car is a street/strip car, mid-10.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: dodge turbo]
#2322422
06/17/17 12:18 AM
06/17/17 12:18 AM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
I run Hancook or Kumho on my satellite , 185/80R15 . A mate runs a taller MT radial front runner at 3900lbs . No mix and match radial/crossply front to rear
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: dodge turbo]
#2322437
06/17/17 12:40 AM
06/17/17 12:40 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Just make sure they are speed rated, I ran Volkswagen tires on my grudge truck back in the day, I will never do that again..........
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: dodge turbo]
#2322635
06/17/17 02:26 PM
06/17/17 02:26 PM
dodge turbo
Yea thats what im worried about is the speed rating I have a regular radial street tire (cooper) and its only rated To 110
[Re: dodge turbo]
#2322727
06/17/17 07:33 PM
06/17/17 07:33 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I run a M/T 315/60 Drag Radial on the back and M/T ET bias ply front runners and mine handles just fine. Have been running this combo for 3 years.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: dodge turbo]
#2322735
06/17/17 08:05 PM
06/17/17 08:05 PM
Posts: 2,286 Hamilton,Ont
72chrgrally
Hamilton,Ont
I asked almost the same question on y/b a short while ago. M/T Sportsman pro was suggested a few times.
Photobucket sucks
[Re: dodge turbo]
#2323493
06/19/17 10:15 AM
06/19/17 10:15 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
I use M/T Sportsman fronts that are 28" tall w/ drag radials out back. My car is about 3900 lbs. It handles fine at the track...on the street is where the bias ply fronts suck. They follow ruts real bad. I'd recommend the M/T Sportsman SR radial they have now that is 28" tall. The M/T 6678 http://www.jegs.com/i/Mickey-Thompson/672/6678/10002/-1It's what I'll be getting for the front of mine next. Don't be concerned w/ the speed rating for a street/strip vehicle. That's for sustained speeds, not short bursts like our cars see. There are tons of FAST cars running 165R15 VW tires for years w/ no issues.
[Re: dodge turbo]
#2323990
06/20/17 02:19 AM
06/20/17 02:19 AM
Posts: 326 Alberta
Wookie316
Alberta
Run the Hoosier 28" skinny and the 10.5x30 radial slick in the back on my sled. 3800 without me and over 4000 once I get in. 130 on the top is nice and stable. Look good as well.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
