Plug size for rocker shaft? #2320519
06/13/17 01:13 PM
06/13/17 01:13 PM
Abilene, Texas
fastmark Online content OP
fastmark  Online Content OP
Abilene, Texas
I need to clean out the inside of stock 440 rocker shaft and driving out the plug in the end seems to be the best solution. Does anyone know the correct size of drive in plug I need before I remove this one for cleaning. It is hard to measure with it still installed.
Re: Plug size for rocker shaft? [Re: fastmark] #2320562
06/13/17 02:38 PM
06/13/17 02:38 PM
They may vary in size from year to year and for after market shafts scope
I would drill and tap them for a NPT plug, if possible scope thumbs
Re: Plug size for rocker shaft? [Re: fastmark] #2320574
06/13/17 02:59 PM
06/13/17 02:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
RockAuto lists them as:
DORMAN 555067 Expansion Plug; Nominal Dia.: 39/64"SC; Metric Dia.; 15.93mm; Steel; Height: 0.200"; Open End Dia.: 0.635
Re: Plug size for rocker shaft? [Re: fastmark] #2320590
06/13/17 03:23 PM
06/13/17 03:23 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I was going to do the same thing on a set of stock small block shafts until I looked up the price on a new set from Summit Racing. I bought new.
Re: Plug size for rocker shaft? [Re: fastmark] #2320678
06/13/17 06:18 PM
06/13/17 06:18 PM
organ
maximum entropy Offline
organ
i reuse 'em. the shafts are not pressurized (they better not be!).
Re: Plug size for rocker shaft? [Re: fastmark] #2320685
06/13/17 06:23 PM
06/13/17 06:23 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I think I seen them on the 440 Source site work
Gus beer
64 Plymouth Savoy
Dana 60
Re: Plug size for rocker shaft? [Re: fastmark] #2320687
06/13/17 06:27 PM
06/13/17 06:27 PM
Abilene, Texas
Abilene, Texas
Well I had to just knock one out and take a chance I could find one today. It was 5/8" so I'm ok. I could not reuse it. It tears it up.
Re: Plug size for rocker shaft? [Re: fastmark] #2320688
06/13/17 06:29 PM
06/13/17 06:29 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Most are 5/8" yes.
RIP Monte Smith
Re: Plug size for rocker shaft? [Re: maximum entropy] #2320719
06/13/17 07:22 PM
06/13/17 07:22 PM
They are pressurized momentarily when the cam oil holes align with the block oil passages, unless you make the rocker arms oil full time like I do on roller cam motors work thumbs
Re: Plug size for rocker shaft? [Re: Cab_Burge] #2320732
06/13/17 07:45 PM
06/13/17 07:45 PM
organ
organ
10-4
