Re: Plug size for rocker shaft?
[Re: fastmark]
#2320574
06/13/17 02:59 PM
06/13/17 02:59 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
RockAuto lists them as:
DORMAN 555067 Expansion Plug; Nominal Dia.: 39/64"SC; Metric Dia.; 15.93mm; Steel; Height: 0.200"; Open End Dia.: 0.635
[Re: fastmark]
#2320678
06/13/17 06:18 PM
06/13/17 06:18 PM
Posts: 5,080 organ
maximum entropy
organ
i reuse 'em. the shafts are not pressurized (they better not be!).
[Re: fastmark]
#2320687
06/13/17 06:27 PM
06/13/17 06:27 PM
Posts: 6,418 Abilene, Texas
fastmark
Abilene, Texas
Well I had to just knock one out and take a chance I could find one today. It was 5/8" so I'm ok. I could not reuse it. It tears it up.
[Re: fastmark]
#2320688
06/13/17 06:29 PM
06/13/17 06:29 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
[Re: Cab_Burge]
#2320732
06/13/17 07:45 PM
06/13/17 07:45 PM
Posts: 5,080 organ
maximum entropy
organ
i reuse 'em. the shafts are not pressurized (they better not be!). They are pressurized momentarily when the cam oil holes align with the block oil passages, unless you make the rocker arms oil full time like I do on roller cam motors 10-4
