Re: Just Lost my .590 cam
[Re: BSB67]
#2316421
06/05/17 02:32 AM
06/05/17 02:32 AM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Do I understand this correctly, the 590 was fine, you switched to "the best thing since sliced bread" lifter, and wiped a lobe. Is that correct?
I guess this is one of those instances where two people interpret the same situation two different ways. I heard, "I put new lifters on my 8 year old cam and it wiped a lobe". Which made me think......."why would one try and put new lifters on a well used cam"?
[Re: fast68plymouth]
#2316523
06/05/17 12:03 PM
06/05/17 12:03 PM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have added a couple of things to my list that I got away with years ago but will NEVER try again.
1. I will never buy a used solid lift cam. 2. I will NEVER take a good used solid lift cam from one block and install it in a new build. (different block)
[Re: pittsburghracer]
#2316562
06/05/17 01:19 PM
06/05/17 01:19 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
1. I will never buy a used solid lift cam. 2. I will NEVER take a good used solid lift cam from one block and install it in a new build. (different block) ME; I will NEVER buy ANY solid lifter cam for ANYTHING...........problem solved..........
[Re: Thumperdart]
#2316567
06/05/17 01:26 PM
06/05/17 01:26 PM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
1. I will never buy a used solid lift cam. 2. I will NEVER take a good used solid lift cam from one block and install it in a new build. (different block) ME; I will NEVER buy ANY solid lifter cam for ANYTHING...........problem solved.......... I haven't totally given up on them. I've gone low 9.50's in my small block with them so they have their place.
[Re: Thumperdart]
#2316575
06/05/17 01:50 PM
06/05/17 01:50 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
1. I will never buy a used solid lift cam. 2. I will NEVER take a good used solid lift cam from one block and install it in a new build. (different block) ME; I will NEVER buy ANY solid lifter cam for ANYTHING...........problem solved.......... I use a solid lifter (tool steel) in my RBRE 496 ci. Gone 9.08 @ 146, I have thought about a roller. Maybe when I want to hit the 8s? Don
[Re: 77DragracerR/T]
#2316758
06/05/17 06:59 PM
06/05/17 06:59 PM
Posts: 20,631 in a cattle trailer down by th...
Guitar Jones
That .590 cam was good in its day, which was at least 30 years ago. There is so much better out there now. I went roller awhile back and will never look back.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
#2316969
06/06/17 12:56 AM
06/06/17 12:56 AM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
I guess this is one of those instances where two people interpret the same situation two different ways. I heard, "I put new lifters on my 8 year old cam and it wiped a lobe". Which made me think......."why would one try and put new lifters on a well used cam"? Thought that too
