Re: Just Lost my .590 cam
[Re: BSB67]
#2316421
06/05/17 02:32 AM
06/05/17 02:32 AM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Do I understand this correctly, the 590 was fine, you switched to "the best thing since sliced bread" lifter, and wiped a lobe. Is that correct?
I guess this is one of those instances where two people interpret the same situation two different ways. I heard, "I put new lifters on my 8 year old cam and it wiped a lobe". Which made me think......."why would one try and put new lifters on a well used cam"?
[Re: fast68plymouth]
#2316523
06/05/17 12:03 PM
06/05/17 12:03 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have added a couple of things to my list that I got away with years ago but will NEVER try again.
1. I will never buy a used solid lift cam. 2. I will NEVER take a good used solid lift cam from one block and install it in a new build. (different block)
[Re: pittsburghracer]
#2316562
06/05/17 01:19 PM
06/05/17 01:19 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
1. I will never buy a used solid lift cam. 2. I will NEVER take a good used solid lift cam from one block and install it in a new build. (different block) ME; I will NEVER buy ANY solid lifter cam for ANYTHING...........problem solved..........
[Re: Thumperdart]
#2316567
06/05/17 01:26 PM
06/05/17 01:26 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
1. I will never buy a used solid lift cam. 2. I will NEVER take a good used solid lift cam from one block and install it in a new build. (different block) ME; I will NEVER buy ANY solid lifter cam for ANYTHING...........problem solved.......... I haven't totally given up on them. I've gone low 9.50's in my small block with them so they have their place.
[Re: Thumperdart]
#2316575
06/05/17 01:50 PM
06/05/17 01:50 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
1. I will never buy a used solid lift cam. 2. I will NEVER take a good used solid lift cam from one block and install it in a new build. (different block) ME; I will NEVER buy ANY solid lifter cam for ANYTHING...........problem solved.......... I use a solid lifter (tool steel) in my RBRE 496 ci. Gone 9.08 @ 146, I have thought about a roller. Maybe when I want to hit the 8s? Don
[Re: 77DragracerR/T]
#2316758
06/05/17 06:59 PM
06/05/17 06:59 PM
Guitar Jones
That .590 cam was good in its day, which was at least 30 years ago. There is so much better out there now. I went roller awhile back and will never look back.
#2316969
06/06/17 12:56 AM
06/06/17 12:56 AM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
I guess this is one of those instances where two people interpret the same situation two different ways. I heard, "I put new lifters on my 8 year old cam and it wiped a lobe". Which made me think......."why would one try and put new lifters on a well used cam"? Thought that too
