e body header panel i.d.71 or 72? #2315819
06/04/17 03:30 AM
06/04/17 03:30 AM
Loganville GA.
K
kdsmith07 Offline OP
K
Loganville GA.
anyone know if this is a 71 or a 72.i took pics of the bottle shaped holes on the underside for the grille i'm assuming.thanks for any info,kent
Re: e body header panel i.d.71 or 72? [Re: kdsmith07] #2315822
06/04/17 04:17 AM
06/04/17 04:17 AM
Maryland
MoparMike1974 Offline
Maryland
Im curious to know what the difference is in the 72+ and the 71 header. I know its a different part #. AMD couldnt tell me the difference when I was ordering the parts to convert my 74 to a 71.
Re: e body header panel i.d.71 or 72? [Re: MoparMike1974] #2315830
06/04/17 05:07 AM
06/04/17 05:07 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
the reinforcement isn't on my pre-production '71's grill support/header
pic of a spring '71 'cuda w/reinforcement (is it actually an early/late '71 issue also?) or does the tab on the end point in a different direction?
Re: e body header panel i.d.71 or 72? [Re: kdsmith07] #2315892
06/04/17 12:28 PM
06/04/17 12:28 PM
Maryland
Maryland
My 74 is buried in the end of a 40' connex box. If I could get to it I would compare the new AMD 71 part to my original 74.
Re: e body header panel i.d.71 or 72? [Re: kdsmith07] #2315945
06/04/17 02:00 PM
06/04/17 02:00 PM
Loganville GA.
K
K
Loganville GA.
ok,it looks like it's a 72 up.thanks guys
Re: e body header panel i.d.71 or 72? [Re: kdsmith07] #2315953
06/04/17 02:31 PM
06/04/17 02:31 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Looks just like the one I pulled off my 72 yesterday. It has the reinforcement plate also.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: e body header panel i.d.71 or 72? [Re: Silver70] #2315954
06/04/17 02:34 PM
06/04/17 02:34 PM
BRIDGEWATER, CT.
WINGNUT Offline
WINGNUT  Offline
BRIDGEWATER, CT.
The "reinforcement plate" is actually for mounting the horns on.
Re: e body header panel i.d.71 or 72? [Re: kdsmith07] #2315966
06/04/17 02:53 PM
06/04/17 02:53 PM
Loganville GA.
K
K
Loganville GA.
thanks again for the reply's.much appreciated,kent
Re: e body header panel i.d.71 or 72? [Re: kdsmith07] #2315987
06/04/17 03:25 PM
06/04/17 03:25 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
so ..... for '71 the horns are mounted behind the washer bottle on the passenger inner fender
to make room for the "new for '72" charcoal canister on the passenger side inner fender, the horns were moved to the modified center grill support up
Re: e body header panel i.d.71 or 72? [Re: 6bblgt] #2316078
06/04/17 05:51 PM
06/04/17 05:51 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
..PLUS...the 'bottle shaped ' openings face opposite to 72-up on this true 71 valance, 3 one way , one the other.
Not just as simple as removing the bracket to make a 72 grill header become a 71.
The 4 'openings' that take the plastic threaded grommet on a 72 header will not line up with the corresponding support areas on a 71 grill without reworking these areas.
Re: e body header panel i.d.71 or 72? [Re: kdsmith07] #2316381
06/05/17 01:13 AM
06/05/17 01:13 AM
Loganville GA.
K
K
Loganville GA.
that's some good info,thanks
