Re: e body header panel i.d.71 or 72?
[Re: kdsmith07]
#2315953
06/04/17 02:31 PM
06/04/17 02:31 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Looks just like the one I pulled off my 72 yesterday. It has the reinforcement plate also.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: 6bblgt]
#2316078
06/04/17 05:51 PM
06/04/17 05:51 PM
Posts: 4,785 Ontario, Canada
mccannix
Ontario, Canada
so ..... for '71 the horns are mounted behind the washer bottle on the passenger inner fender to make room for the "new for '72" charcoal canister on the passenger side inner fender, the horns were moved to the modified center grill support ..PLUS...the 'bottle shaped ' openings face opposite to 72-up on this true 71 valance, 3 one way , one the other. Not just as simple as removing the bracket to make a 72 grill header become a 71. The 4 'openings' that take the plastic threaded grommet on a 72 header will not line up with the corresponding support areas on a 71 grill without reworking these areas.
