Page 3 of 3 1 2 3
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2296059
04/29/17 01:10 PM
04/29/17 01:10 PM
Canada
WO23Coronet Offline OP
Canada
I remember before this crate engine Mopar had another one listed, as a retrofit into older (95 and earlier)Rams?
Re: Mopar is making a retrofit kit! [Re: WO23Coronet] #2311656
05/26/17 06:08 PM
05/26/17 06:08 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I just installed one of those kits in a cuda in the last couple weeks. It was easy, I guess. There was at least one drawback to the kit. The harness to the computer could be longer. It doesn't leave much room in the older cars to keep things clean. Unless you want to just bolt it to the fire wall. Then the fuse/relay box placement. I was able to hide everything. I'll have to post some pics.
Re: Mopar is making a retrofit kit! [Re: DANA60] #2311667
05/26/17 06:25 PM
05/26/17 06:25 PM
USA
hudsonhornet7x Offline
USA
Please do. I will be doing this soon and would love to see how you did it.
Page 3 of 3 1 2 3
