Info needed for valve cover markings #2303868
05/13/17 03:52 PM
05/13/17 03:52 PM
69x Offline OP
69x  Offline OP
I have seen some cars that have black markings on the front of their valve covers, usually numbers and or a letter.
What would be the correct markings for a 69 440 4-speed ?
I saw a very nice Daytona 440 4 speed car that had a 915 on the front of the pass side valve cover and on the drivers side there was a O on the front, would that be correct for my GTX ?
Also can someone tell me what they mean ? I am guessing maybe engine type and trans type ? did all of these cars have those markings or only some and what type of a marker would a person use to put them on, I would think over time they would maybe burn off.
Re: Info needed for valve cover markings [Re: 69x] #2303892
05/13/17 05:19 PM
05/13/17 05:19 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Although not the norm, along with a 125 on the front, I had these markings on an original set of 69 hi-po 440 valve covers that I removed years ago.
A few dings and paint runs as well.
Re: Info needed for valve cover markings [Re: 69x] #2304035
05/13/17 10:04 PM
05/13/17 10:04 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Re: Info needed for valve cover markings [Re: 69x] #2304179
05/14/17 02:49 AM
05/14/17 02:49 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Do you have your broadcast sheet?
Re: Info needed for valve cover markings [Re: Morty426] #2304181
05/14/17 03:12 AM
05/14/17 03:12 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
or a fender tag?
Re: Info needed for valve cover markings [Re: A12] #2304230
05/14/17 11:12 AM
05/14/17 11:12 AM
69x Offline OP
69x  Offline OP
Just the fender tag, only about 15 percent of the BC found under the bucket seat.
Re: Info needed for valve cover markings [Re: 69x] #2304282
05/14/17 01:08 PM
05/14/17 01:08 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
One valve cover will have the engine number from the BC
The other cover may have nothing or a carb code or a character denoting trans type.
The only way to know for sure is to document what the car had when you took it apart, if possible.
Re: Info needed for valve cover markings [Re: 69x] #2306373
05/17/17 11:00 PM
05/17/17 11:00 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Is this a Lynch Road assembly plant built GTX?
Re: Info needed for valve cover markings [Re: 69x] #2306377
05/17/17 11:07 PM
05/17/17 11:07 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Those markings are sound correct for a 69 440 4speed from what I remember. 915 on pass. side denotes the 440 and 0 on driver side denotes the 4 speed
Ron
Re: Info needed for valve cover markings [Re: RJS] #2306383
05/17/17 11:19 PM
05/17/17 11:19 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I know the engine's part number (last three of the part number) is on the Lynch Road built fender tag for '69 not sure of the other plant fender tags. This is a survivor '69 383 automatic Super Bee's fender tag and valve cover marking. "899" is on the tag along with the trans and axle. (it's an A/C car with a turquoise-blue engine)
Mike
Re: Info needed for valve cover markings [Re: A12] #2306568
05/18/17 10:09 AM
05/18/17 10:09 AM
69x Offline OP
69x  Offline OP
No, St louis
