Re: Info needed for valve cover markings
[Re: Morty426]
#2304181
05/14/17 03:12 AM
05/14/17 03:12 AM
Posts: 21,505 N.E. OHIO, USA
A12
N.E. OHIO, USA
Do you have your broadcast sheet? or a fender tag?
[Re: 69x]
#2306377
05/17/17 11:07 PM
05/17/17 11:07 PM
Posts: 6,224 JERSEY
RJS
JERSEY
I have seen some cars that have black markings on the front of their valve covers, usually numbers and or a letter.
What would be the correct markings for a 69 440 4-speed ? I saw a very nice Daytona 440 4 speed car that had a 915 on the front of the pass side valve cover and on the drivers side there was a O on the front, would that be correct for my GTX ?
Also can someone tell me what they mean ? I am guessing maybe engine type and trans type ? did all of these cars have those markings or only some and what type of a marker would a person use to put them on, I would think over time they would maybe burn off.
Thanks Those markings are sound correct for a 69 440 4speed from what I remember. 915 on pass. side denotes the 440 and 0 on driver side denotes the 4 speed Ron
[Re: RJS]
#2306383
05/17/17 11:19 PM
05/17/17 11:19 PM
A12
N.E. OHIO, USA
I know the engine's part number (last three of the part number) is on the Lynch Road built fender tag for '69 not sure of the other plant fender tags. This is a survivor '69 383 automatic Super Bee's fender tag and valve cover marking. "899" is on the tag along with the trans and axle. (it's an A/C car with a turquoise-blue engine)
Mike
[Re: A12]
#2306568
05/18/17 10:09 AM
05/18/17 10:09 AM
69x
Is this a Lynch Road assembly plant built GTX? No, St louis
