Re: Dynomat on Roof or Jute Insulation, or both? [Re: lockjaw-express] #2303538
05/12/17 08:57 PM
05/12/17 08:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
On your comment on the added weight of the paint I believe a lot of the paint weight evaporates when sprayed onto the car work scope
I had heard back in the early 1970s to not spray much paint on out race cars and then someone weighed his race car before and 30 days after the paint job and found that it had not gained the amount of weight that the paint weighed confused shruggy
Re: Dynomat on Roof or Jute Insulation, or both? [Re: Cab_Burge] #2304012
05/13/17 09:26 PM
05/13/17 09:26 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I use jute with 3M 90 on the roof. I don't like foil covered butyl (aka Dynamat, etc.) because it sweats and stains the headliner.
That said the only time I have issues with the roof sweating is with cars we don't have in a climate controlled shop.
I like the just glued to the dynamat idea though. I was too paranoid that the roof in my winter beater Coronet would rot from the inside out.
Re: Dynomat on Roof or Jute Insulation, or both? [Re: lockjaw-express] #2304118
05/14/17 12:16 AM
05/14/17 12:16 AM
Ohio
lockjaw-express Offline OP
Ohio
Jerimiah,
Good point on the condensation issue!
I will put the Superlite Dynamat up first, and then glue on the Jute.
Thanks, Mark
Re: Dynomat on Roof or Jute Insulation, or both? [Re: Jeremiah] #2304575
05/14/17 10:54 PM
05/14/17 10:54 PM
Albany, New York
66Plymouth440Six Offline
Albany, New York
Jeremiah -
Did you tape all the seams? I was wondering if it still sweats/ discolors if all the seams are taped. I just did a roof with the foil-lined butyl and was curious.
1966 Plymouth Satellite 440 6bbl
Re: Dynomat on Roof or Jute Insulation, or both? [Re: lockjaw-express] #2304731
05/15/17 08:54 AM
05/15/17 08:54 AM
Australia
dodgy Offline
dodgy  Offline
Australia
did that to my ute, no problems 6+ years on in hot aussie climate
then put a house roof insulation over dynomat its high denc foam with foil both sides.
Re: Dynomat on Roof or Jute Insulation, or both? [Re: lockjaw-express] #2304775
05/15/17 11:11 AM
05/15/17 11:11 AM
Ohio
Ohio
Hi Dodgy,
What did you put over the Dynamat, and did you glue it? and if so, what glue did you use? 3M 90?
Thank you!
Mark
