Re: anyone know who has program to CNC -mopar stage 6 heads?
[Re: GLR]
#2303416
05/12/17 04:26 PM
05/12/17 04:26 PM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
This wont be of any help to you...... But...... Before the Chapman stage 6's arrived on the scene, MP offered a CNC ported version of the std stage 6. I have what I believe is a set of those here in the shop(they have been CNC ported with a pretty coarse program), and fwiw...... They don't flow anything special as they came ootb. I would consider the porting that was done a nice head start on getting the bulk of the major "hogging" out of the way.......... Other than too much was actually removed from the exhaust floor. https://board.moparts.org/ubbthreads/ubbt...tml#Post2210676
[Re: GLR]
#2303421
05/12/17 04:41 PM
05/12/17 04:41 PM
Posts: 369 Indy
496 A-body
Indy
[Re: GLR]
#2303668
05/13/17 01:11 AM
05/13/17 01:11 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
I'd also recommend KG engines. Dave does great work and can set them up anyway you want.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: scottb]
#2303748
05/13/17 09:58 AM
05/13/17 09:58 AM
Posts: 20,164 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Some of you guys kill me on thinking that EVERYTHING has to be CNC'd. LOL
[Re: pittsburghracer]
#2303767
05/13/17 10:48 AM
05/13/17 10:48 AM
Posts: 559 Idaho
LaRoy Engines
Idaho
Some of you guys kill me on thinking that EVERYTHING has to be CNC'd. LOL Yep, I hear ya.
[Re: GLR]
#2303830
05/13/17 01:56 PM
05/13/17 01:56 PM
fast68plymouth
So. Burlington, Vt.
I find it can tough to compete price-wise with the CNC jobs, especially for applications where the heads to be ported are getting "extensively" modified.
None of the ones I ported ever put up "the big number" on the flow bench, but they all seemed to go pretty well in the cars they were used in.
IMO, the biggest restriction to flow with the non-Chapman stage 6's is the lack of intake port height under the valve spring.
With all the head options out there today, I think by the time you fix all the typical stage 6-isms, and buy all the parts, and have them fully ported...... I can see where you'd have more into them than some other "better" options....... And that's even if the castings themselves were free.
[Re: GLR]
#2304423
05/14/17 05:46 PM
05/14/17 05:46 PM
Posts: 610 long time lurker, short time p...
PorkyPig
The heads will probably be going on a 400 block-stroked to 512 street/strip use. not sure on induction system yet. Better nail down those decisions before you put any money into those heads, in case they turn out to be a poor choice after all.
[Re: rebel]
#2304425
05/14/17 05:48 PM
05/14/17 05:48 PM
PorkyPig
i would just send them to Larry Smith, his port job on my -1's outflows the cnc port job, but then it depends on how you want to use them. I have a set of Stage 6's on my 512 in my streetcar. they flow 350cfm@650 & my 'cuda has run 10.5's with them. Can you give more details on your 512?
[Re: GLR]
#2304453
05/14/17 07:01 PM
05/14/17 07:01 PM
Posts: 13,185 aZLiViN
J_BODY
aZLiViN
[Re: fast68plymouth]
#2304522
05/14/17 09:28 PM
05/14/17 09:28 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
With all the head options out there today, I think by the time you fix all the typical stage 6-isms, and buy all the parts, and have them fully ported...... I can see where you'd have more into them than some other "better" options....... And that's even if the castings themselves were free. Prime observations and advice. You have to beat Stage VI heads into submission. There are much better options out there........unless......you can do all the work on these heads yourself. And then, there are still better options than these dinosaurs.
[Re: GLR]
#2304610
05/14/17 11:51 PM
05/14/17 11:51 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
NAY NAY NAY.. Ill show ya..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: GLR]
#2305201
05/15/17 10:40 PM
05/15/17 10:40 PM
Posts: 16,474 On the run…
BloFish
On the run…
Well I may have some news for ya soon.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
