Replacing Power Steering Gear Box in 72 Challenger #2292775
04/23/17 04:01 PM
04/23/17 04:01 PM
Fairfield, Ohio
holtzdog55 Offline OP
Fairfield, Ohio
How hard is it to replace the steering box with a rebuilt one? is there any kind of alignment that needs to be done? does fluid need to be flushed out or can you just replace the gear box and start it up? I dont know much on the things that may need to be done confused ....should I have a shop replace it instead?? shruggy
Thanks in advance.....
Finally Done....BEERS!!!
Re: Replacing Power Steering Gear Box in 72 Challenger [Re: holtzdog55] #2292777
04/23/17 04:10 PM
04/23/17 04:10 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If you have a few tools and no headers its nor terrible.Yes flush the systeNot much to that just drain the pump when unit is off and hoses disconnected.You will need a pitman arm puller and have to remove the pot coupler.Id pour some clean fluid thur the pum when its off.Should just bolt right in where the old one came off.Been doing it for years so its easy for me.Rocky
Chrysler Firepower
Re: Replacing Power Steering Gear Box in 72 Challenger [Re: holtzdog55] #2292795
04/23/17 04:40 PM
04/23/17 04:40 PM
Fairfield, Ohio
Fairfield, Ohio
lol...you got me at the pitman arm puller.....and have know idea what the pot coupler is.....figure I better just let the shop do it.....BTW....it has headers on too....
Thanks.....
Re: Replacing Power Steering Gear Box in 72 Challenger [Re: holtzdog55] #2292799
04/23/17 04:48 PM
04/23/17 04:48 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Pot coupler houses the shoes and acts as the connection between the column and the box.
Re: Replacing Power Steering Gear Box in 72 Challenger [Re: holtzdog55] #2292804
04/23/17 04:51 PM
04/23/17 04:51 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If you don't have a factory service manual, that is the first thing you should get. And instead of going to a parts store to get a rebuilt unit, have your's rebuilt by Firm Feel.
Re: Replacing Power Steering Gear Box in 72 Challenger [Re: holtzdog55] #2292851
04/23/17 06:35 PM
04/23/17 06:35 PM
Fairfield, Ohio
Fairfield, Ohio
Stages I, II, III (Rebuilds)
PSB1.......$359
PSB2.......$359
PSB3.......$379
Above is for Firm Feel.....+ $200 for core
No offense but think I'll just get a rebuilt one from CARiD......
A1 CardoneĀ® - Remanufactured Power Steering Gear Box
0 reviews / Item # mpn687310 View Similar Products
$91.18 Core Deposit: $34.65
Re: Replacing Power Steering Gear Box in 72 Challenger [Re: holtzdog55] #2292874
04/23/17 07:08 PM
04/23/17 07:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A1 Cardone = crap with a shiny paint job
After doing it once you will hate doing it again.
Don't be the exception.
Re: Replacing Power Steering Gear Box in 72 Challenger [Re: Supercuda] #2292876
04/23/17 07:10 PM
04/23/17 07:10 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
You got one with shiny paint? You did better than most of us.
Re: Replacing Power Steering Gear Box in 72 Challenger [Re: holtzdog55] #2292889
04/23/17 07:50 PM
04/23/17 07:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Well, I figured he'd spring for the premium one
Re: Replacing Power Steering Gear Box in 72 Challenger [Re: holtzdog55] #2292898
04/23/17 08:08 PM
04/23/17 08:08 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Ok, so, what's wrong with the one in your car?
Re: Replacing Power Steering Gear Box in 72 Challenger [Re: 71birdJ68] #2292924
04/23/17 09:31 PM
04/23/17 09:31 PM
Fairfield, Ohio
Fairfield, Ohio
One in car is leaking....original one.... replaced the Federal pump a few years ago with reconditioned one from Cardone and no leaks from it since boogie ....lol
I just dont have the tools or know how wrench ....besides that cash poor at the moment.... bawling
Wish I did have a few grand sitting around.....lol drinking
Beers!!! beer
Re: Replacing Power Steering Gear Box in 72 Challenger [Re: holtzdog55] #2293010
04/24/17 12:03 AM
04/24/17 12:03 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Can you tell exactly where it is leaking? From what you just said, it will be a lot easer, and cheaper to buy a seal kit, and have someone that knows how just reseal the one you have than trying to remove and replace it. For one thing the steering column will have to be either removed, or dropped and slid back a little. For instance, if it's leaking from the bottom, that seal can be replaced from the bottom.
Re: Replacing Power Steering Gear Box in 72 Challenger [Re: holtzdog55] #2293127
04/24/17 10:29 AM
04/24/17 10:29 AM
Fairfield, Ohio
Fairfield, Ohio
It"s at the shop now....I'll have to check to see if they can replace seals instead....checked around and non are available right now unless you go to Year One or Summit which want 5-600 with core and return shipping....Advance Auto or CariD are saying Mid May or later.....Thanks for all the advice....Tony
Re: Replacing Power Steering Gear Box in 72 Challenger [Re: holtzdog55] #2294431
04/26/17 12:07 PM
04/26/17 12:07 PM
pa.
dan9 Offline
dan9  Offline
pa.
Be sure to remove the nipple fitting, (2) 1/4 in. bolts where the return line attaches to the box. If not you will surely break it when you try to get the box down and out. If you decide to replace it I think you will be happy with firm feel stage 3.
