Replacing Power Steering Gear Box in 72 Challenger
#2292775
04/23/17 04:01 PM
04/23/17 04:01 PM
Posts: 445 Fairfield, Ohio
holtzdog55
Fairfield, Ohio
How hard is it to replace the steering box with a rebuilt one? is there any kind of alignment that needs to be done? does fluid need to be flushed out or can you just replace the gear box and start it up? I dont know much on the things that may need to be done ....should I have a shop replace it instead?? Thanks in advance.....
Finally Done....BEERS!!!
Re: Replacing Power Steering Gear Box in 72 Challenger
[Re: holtzdog55]
#2292777
04/23/17 04:10 PM
04/23/17 04:10 PM
Posts: 21,064 Niles , Ohio
therocks
Niles , Ohio
If you have a few tools and no headers its nor terrible.Yes flush the systeNot much to that just drain the pump when unit is off and hoses disconnected.You will need a pitman arm puller and have to remove the pot coupler.Id pour some clean fluid thur the pum when its off.Should just bolt right in where the old one came off.Been doing it for years so its easy for me.Rocky
Chrysler Firepower
[Re: holtzdog55]
#2292795
04/23/17 04:40 PM
04/23/17 04:40 PM
holtzdog55
Fairfield, Ohio
lol...you got me at the pitman arm puller.....and have know idea what the pot coupler is.....figure I better just let the shop do it.....BTW....it has headers on too....
Thanks.....
[Re: holtzdog55]
#2292851
04/23/17 06:35 PM
04/23/17 06:35 PM
holtzdog55
Fairfield, Ohio
Stages I, II, III (Rebuilds)
PSB1.......$359 PSB2.......$359 PSB3.......$379
Above is for Firm Feel.....+ $200 for core
No offense but think I'll just get a rebuilt one from CARiD...... A1 CardoneĀ® - Remanufactured Power Steering Gear Box 0 reviews / Item # mpn687310 View Similar Products
$91.18 Core Deposit: $34.65
[Re: holtzdog55]
#2292874
04/23/17 07:08 PM
04/23/17 07:08 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
A1 Cardone = crap with a shiny paint job
After doing it once you will hate doing it again.
[Re: Supercuda]
#2292876
04/23/17 07:10 PM
04/23/17 07:10 PM
Posts: 2,782 USA
JoesMopar
USA
After doing it once you will hate doing it again. You got one with shiny paint? You did better than most of us.
[Re: holtzdog55]
#2292889
04/23/17 07:50 PM
04/23/17 07:50 PM
Supercuda
About to go away
About to go away
up yours
Well, I figured he'd spring for the premium one
[Re: 71birdJ68]
#2292924
04/23/17 09:31 PM
04/23/17 09:31 PM
holtzdog55
Fairfield, Ohio
One in car is leaking....original one.... replaced the Federal pump a few years ago with reconditioned one from Cardone and no leaks from it since ....lol I just dont have the tools or know how ....besides that cash poor at the moment.... Wish I did have a few grand sitting around.....lol Beers!!!
[Re: holtzdog55]
#2293010
04/24/17 12:03 AM
04/24/17 12:03 AM
Posts: 4,445 Morristown Tn.
71birdJ68
Morristown Tn.
Can you tell exactly where it is leaking? From what you just said, it will be a lot easer, and cheaper to buy a seal kit, and have someone that knows how just reseal the one you have than trying to remove and replace it. For one thing the steering column will have to be either removed, or dropped and slid back a little. For instance, if it's leaking from the bottom, that seal can be replaced from the bottom.
[Re: holtzdog55]
#2293127
04/24/17 10:29 AM
04/24/17 10:29 AM
holtzdog55
Fairfield, Ohio
It"s at the shop now....I'll have to check to see if they can replace seals instead....checked around and non are available right now unless you go to Year One or Summit which want 5-600 with core and return shipping....Advance Auto or CariD are saying Mid May or later.....Thanks for all the advice....Tony
[Re: holtzdog55]
#2294431
04/26/17 12:07 PM
04/26/17 12:07 PM
Posts: 1,023 pa.
dan9
pa.
Be sure to remove the nipple fitting, (2) 1/4 in. bolts where the return line attaches to the box. If not you will surely break it when you try to get the box down and out. If you decide to replace it I think you will be happy with firm feel stage 3.
