fuel pump cooling shroud #2290387
04/19/17 01:35 AM
04/19/17 01:35 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
anyone ever use an fuel pump shroud to cool their mechanical fuel pump?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: fuel pump cooling shroud [Re: astjp2] #2290450
04/19/17 08:58 AM
04/19/17 08:58 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Being that the pumps are mounted forward on the block, I don't really think heat is an issue. I have yet to ever see a mechanical fuel pump get real hot on its own. It's more important to keep heat off of the fuel line passing the exhaust.
[image][/image]
Re: fuel pump cooling shroud [Re: sgcuda] #2290460
04/19/17 09:44 AM
04/19/17 09:44 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
looks like something the TORNADO guys thought up.
Re: fuel pump cooling shroud [Re: astjp2] #2290644
04/19/17 05:54 PM
04/19/17 05:54 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Actually its from 1959, some engines have so much heat in the engine bay that it was used to help prevent vapor lock....cold air was ducted from the front of the engine bay via a hose. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: fuel pump cooling shroud [Re: astjp2] #2290728
04/19/17 09:39 PM
04/19/17 09:39 PM
I don't think the shrouds cool the pumps, they probably deflect the heat good though up work
I think my O540 Lycoming motor had one on it, it was mounted in the rear of the motor is what I remember now ten years after loosing that airplane to a hail storm back in 2006 whiney
Re: fuel pump cooling shroud [Re: astjp2] #2290755
04/19/17 10:51 PM
04/19/17 10:51 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I would have thought for an aircraft, it would be more useful for heating/warming the fuel pump/fuel, since I thought at altitude, temps dropped, especially in inclement weather, and a carb freezing up would be bad. What do I know? realcrazy
Re: fuel pump cooling shroud [Re: astjp2] #2291121
04/20/17 05:49 PM
04/20/17 05:49 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Not sure how much it worked, but here's another example:
http://www.1962to1965mopar.ornocar.com/poly318fuelpumpshield.html
Re: fuel pump cooling shroud [Re: jcc] #2291178
04/20/17 07:41 PM
04/20/17 07:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The temp does drop.. 3 degrees for every 1000 ft.. but a plane
also has carb heat now days... I did a LOT of work with 4 cyl
fuel foaming when the fuel would boil and vaporize and the
engine would almost die on a hard accel.. we came up with a few
things that worked.. the added volume can and the rubber
isolator that many remember on the 4 bangers
wave
Re: fuel pump cooling shroud [Re: jcc] #2291393
04/21/17 01:49 AM
04/21/17 01:49 AM
I would have thought for an aircraft, it would be more useful for heating/warming the fuel pump/fuel, since I thought at altitude, temps dropped, especially in inclement weather, and a carb freezing up would be bad. What do I know? realcrazy [/quote]
The newer (1940 and later maybe)Lycoming aircraft engines, both 4 and 6 cylinders, have the carb. mounted on the bottom of the oil pan with the intake runners running through the oil pan also, usually no problems with carb. ice when warmed up.
I did run into carb. ice once or twice in my 15 yrs. of flying Lycoming powered small aircraft, usually around 8500 Ft or higher in high humid air that was well above freezing OAT shock shruggy
The other major brand, Continental, has the carbs. mounted and separated away from the oil pan and they do get carb. ice a lot easier and a lot more often down
