Not a Mopar but WOW!!!!!!!!! #2281419
04/03/17 11:13 AM
04/03/17 11:13 AM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
https://www.youtube.com/watch?v=VgiglXffzNo
Published on Apr 2, 2017
One of the most INSANE drag racing passes we have filmed in the last 17 years. Daniel Pharris driving Andrew Alepa's beautiful Twin Turbo Corvette -vs- Brandon Pesz during the Radial Revenge event at Tulsa Raceway Park. Driver was out and OK but the car took a brutal hit. It looks like it could have been much worse if the front clip had not peeled off mid flight.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Not a Mopar but WOW!!!!!!!!! [Re: pittsburghracer] #2281439
04/03/17 11:47 AM
04/03/17 11:47 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
We discussed Nascar flaps on YB,This is not the total answer but would help
Re: Not a Mopar but WOW!!!!!!!!! [Re: pittsburghracer] #2281450
04/03/17 12:00 PM
04/03/17 12:00 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
I was streaming the race when it happened,slammed down hard. Good to see he was out of the car so fast and there wasn't a fire.
I was amazed the door opened so easy after that hard of a hit.
up to the chassis builder
72 Plymouth Roadrunner 11.08@123.25
Re: Not a Mopar but WOW!!!!!!!!! [Re: Clanton] #2281454
04/03/17 12:05 PM
04/03/17 12:05 PM
PA.
"Little"John
"Little"John
PA.
Those flaps were a very smart move for NASCAR but only help when going backwards. With a drag cars smooth bottoms I feel this will continue to happen. If they would enforce a mandated front end weigh it would set the class back and I my eyes would be a bad move. It happened and will continue to happened but he his one turned out pretty lucky. Fingers crossed the luck continues
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Not a Mopar but WOW!!!!!!!!! [Re: pittsburghracer] #2281457
04/03/17 12:14 PM
04/03/17 12:14 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Dang! And Keith Haney's 'Enigma' in the other lane trying to avoid the wreckage.
Re: Not a Mopar but WOW!!!!!!!!! [Re: pittsburghracer] #2281480
04/03/17 12:40 PM
04/03/17 12:40 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Second bad mishap with that team this year. Big fire in qualifying at Georgia and now this.
John I would bet that car has 60% nose weight, motor, turbos, fuel cell, battery etc are all in the front.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Not a Mopar but WOW!!!!!!!!! [Re: dustergirl340] #2281482
04/03/17 12:45 PM
04/03/17 12:45 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
It has a Hemi in it, so it's appropriate.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Not a Mopar but WOW!!!!!!!!! [Re: DusterDave] #2281484
04/03/17 12:47 PM
04/03/17 12:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Those "Brand Neutral" Hemi's make some steam!
68 Barracuda Formula S 340
Re: Not a Mopar but WOW!!!!!!!!! [Re: 1967dartgt] #2281516
04/03/17 01:40 PM
04/03/17 01:40 PM
PA.
"Little"John
"Little"John
PA.
Very true and retry sure I saw somewhere it had 2 turbos on it so that's probably even heavier. Man these things fly.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Not a Mopar but WOW!!!!!!!!! [Re: Bad340fish] #2281520
04/03/17 01:44 PM
04/03/17 01:44 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
On of my favorite tracks to race at!
'63 Dodge 330
11.19 @ 121 mph
Re: Not a Mopar but WOW!!!!!!!!! [Re: pittsburghracer] #2281739
04/03/17 05:30 PM
04/03/17 05:30 PM
MI
Dynoguy Offline
Dynoguy  Offline
MI
I was looking through some of of you tube videos of that race it looks like Big Shawn from Street Outlaws knows that guy, he was in one of the videos..
Re: Not a Mopar but WOW!!!!!!!!! [Re: pittsburghracer] #2281942
04/04/17 12:26 AM
04/04/17 12:26 AM
toronto
6PAK70CUDA Offline
6PAK70CUDA  Offline
toronto
I know its against all the "bad-ass street rules" to do so but how about some wheelie bars if you are going to put down that much HP?
Re: Not a Mopar but WOW!!!!!!!!! [Re: 6PAK70CUDA] #2281948
04/04/17 12:39 AM
04/04/17 12:39 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Not to you 6pac, But why did Both cars flip up so easily. WTH???
Re: Not a Mopar but WOW!!!!!!!!! [Re: pittsburghracer] #2281966
04/04/17 12:55 AM
04/04/17 12:55 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Track prep is why. They Glue the Surface so much it is like fly paper.
No spin = dead hooked
Re: Not a Mopar but WOW!!!!!!!!! [Re: FastmOp] #2282144
04/04/17 12:33 PM
04/04/17 12:33 PM
Roughbird72 Offline
Roughbird72  Offline
Yep, those two car were the first on a fresh prepped track.
Re: Not a Mopar but WOW!!!!!!!!! [Re: Roughbird72] #2282227
04/04/17 02:27 PM
04/04/17 02:27 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
IMO it's idiocy racing without wheelie bars. These blowovers are far too common. Just a matter of time before rules mandate them. I would never run my car without bars.
Re: Not a Mopar but WOW!!!!!!!!! [Re: pittsburghracer] #2282318
04/04/17 04:48 PM
04/04/17 04:48 PM
MI
Dynoguy Offline
Dynoguy  Offline
MI
Depending on what class he is running some classes don't allow wheelie bars..
Re: Not a Mopar but WOW!!!!!!!!! [Re: Dynoguy] #2282597
04/05/17 12:35 AM
04/05/17 12:35 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
considering BobR's car is just as fast as either one of those cars... I'm pretty sure he understands the rules
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Not a Mopar but WOW!!!!!!!!! [Re: WHITEDART] #2282638
04/05/17 02:09 AM
04/05/17 02:09 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
No offense to BobR but his car isn't as fast as these cars. The one that blew over has been deep in the 3.70s and was the third fastest radial car in the country this year.
Second a set of wheelie bars won't work on a car at the 330' mark going 130+ mph on a radial that is dead hooked. It would either ride up on the wheelie bars or break them at those speeds.
