Not a Mopar but WOW!!!!!!!!!
#2281419
04/03/17 11:13 AM
04/03/17 11:13 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
https://www.youtube.com/watch?v=VgiglXffzNoPublished on Apr 2, 2017 One of the most INSANE drag racing passes we have filmed in the last 17 years. Daniel Pharris driving Andrew Alepa's beautiful Twin Turbo Corvette -vs- Brandon Pesz during the Radial Revenge event at Tulsa Raceway Park. Driver was out and OK but the car took a brutal hit. It looks like it could have been much worse if the front clip had not peeled off mid flight.
Re: Not a Mopar but WOW!!!!!!!!!
[Re: pittsburghracer]
#2281450
04/03/17 12:00 PM
04/03/17 12:00 PM
Posts: 1,237 North Central, Indiana
Roughbird72
I was streaming the race when it happened,slammed down hard. Good to see he was out of the car so fast and there wasn't a fire. I was amazed the door opened so easy after that hard of a hit. to the chassis builder
72 Plymouth Roadrunner 11.08@123.25
[Re: Clanton]
#2281454
04/03/17 12:05 PM
04/03/17 12:05 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
We discussed Nascar flaps on YB,This is not the total answer but would help Those flaps were a very smart move for NASCAR but only help when going backwards. With a drag cars smooth bottoms I feel this will continue to happen. If they would enforce a mandated front end weigh it would set the class back and I my eyes would be a bad move. It happened and will continue to happened but he his one turned out pretty lucky. Fingers crossed the luck continues
#2281480
04/03/17 12:40 PM
04/03/17 12:40 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Second bad mishap with that team this year. Big fire in qualifying at Georgia and now this.
John I would bet that car has 60% nose weight, motor, turbos, fuel cell, battery etc are all in the front.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: dustergirl340]
#2281482
04/03/17 12:45 PM
04/03/17 12:45 PM
Posts: 1,845 Tampa
DusterDave
Tampa
It has a Hemi in it, so it's appropriate.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#2281484
04/03/17 12:47 PM
04/03/17 12:47 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
It has a Hemi in it, so it's appropriate. Those "Brand Neutral" Hemi's make some steam!
68 Barracuda Formula S 340
[Re: 1967dartgt]
#2281516
04/03/17 01:40 PM
04/03/17 01:40 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
John I would bet that car has 60% nose weight, motor, turbos, fuel cell, battery etc are all in the front. Very true and retry sure I saw somewhere it had 2 turbos on it so that's probably even heavier. Man these things fly.
[Re: Bad340fish]
#2281520
04/03/17 01:44 PM
04/03/17 01:44 PM
Posts: 4,687 Wichita
GY3
Wichita
On of my favorite tracks to race at!
[Re: Dynoguy]
#2282597
04/05/17 12:35 AM
04/05/17 12:35 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Depending on what class he is running some classes don't allow wheelie bars.. considering BobR's car is just as fast as either one of those cars... I'm pretty sure he understands the rules
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2282638
04/05/17 02:09 AM
04/05/17 02:09 AM
1967dartgt
Hilltown Pa
Depending on what class he is running some classes don't allow wheelie bars.. considering BobR's car is just as fast as either one of those cars... I'm pretty sure he understands the rules No offense to BobR but his car isn't as fast as these cars. The one that blew over has been deep in the 3.70s and was the third fastest radial car in the country this year. Second a set of wheelie bars won't work on a car at the 330' mark going 130+ mph on a radial that is dead hooked. It would either ride up on the wheelie bars or break them at those speeds.
