Re: 2004 Dually Trailer Harness
[Re: Dave Hall]
#2276867
03/26/17 11:52 PM
03/26/17 11:52 PM
Posts: 643 southern conn
1969gtx
southern conn
Does this happen with the key on only or off to . And if you ck for power on the turn/brake terminal at the plug. There a diagram on the cover if it's a factory plug w/ key off should only be power at battery
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
