2004 Dually Trailer Harness #2276633
03/26/17 05:30 PM
03/26/17 05:30 PM
Cotati, CA
Dave Hall Offline OP
Cotati, CA
My dually is sending the left brake/signal to the trailer harness. So the left brake light is on as soon as I plug in any trailer. I checked the harness all the way to the fuse box and can't find anything. The wiring diagram shows a relay after the fuse #46 but I can't locate it for the life of me.
Re: 2004 Dually Trailer Harness [Re: Dave Hall] #2276867
03/26/17 11:52 PM
03/26/17 11:52 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
Does this happen with the key on only or off to . And if you ck for power on the turn/brake terminal at the plug. There a diagram on the cover if it's a factory plug w/ key off should only be power at battery
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: 2004 Dually Trailer Harness [Re: 1969gtx] #2276907
03/27/17 12:52 AM
03/27/17 12:52 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Probably just another bad TIPM, it will only cost you $600 or so to fix it if you can find one. eyes I played hell trying to fix my trailer running lights and turn signals as the TIPM was giving me fits from around 2006 until I sold the truck... mad
JB Rhinehart, Realist
A-Body's RULE!
Re: 2004 Dually Trailer Harness [Re: Dave Hall] #2276937
03/27/17 01:32 AM
03/27/17 01:32 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
quick youtube search found this
link
Re: 2004 Dually Trailer Harness [Re: Dave Hall] #2276963
03/27/17 03:35 AM
03/27/17 03:35 AM
Cotati, CA
Cotati, CA
Thanks guys! Yes the left brake light on the trailer only is on all the time. Yes the left turn/brake pin is constantly hot. The fix doesn't look so hard from the video. My next question is, would a failed relay keep something constantly hot? Seems to me it would be the other way and not send any signal? Thoughts?
Re: 2004 Dually Trailer Harness [Re: Dave Hall] #2276968
03/27/17 04:09 AM
03/27/17 04:09 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Well, I suppose a relay could somehow stick then fail, but that seems far fetched.
I definitely would open up that TIPM and get a meter on the contacts to see whats going on
Re: 2004 Dually Trailer Harness [Re: Dave Hall] #2277002
03/27/17 08:57 AM
03/27/17 08:57 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My bet is the relays rating is to low. The contacts over heated and fused together.
Doug
Re: 2004 Dually Trailer Harness [Re: dvw] #2277049
03/27/17 11:27 AM
03/27/17 11:27 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
You can repair it all you want, but this is just the start of things to come, DAMHIK! Do a lot of research on the TIPM, what a piece of junk! rant
A-Body's RULE!
Re: 2004 Dually Trailer Harness [Re: Dave Hall] #2277247
03/27/17 04:47 PM
03/27/17 04:47 PM
Cotati, CA
Cotati, CA
Ok. Sorry for your troubles Rhino. I'm guessing the TIPM is the fuse/relay center box. This thing has been solid for 300,000 miles. ROCK solid! I wouldn't call it junk. If a $600 bill gets me another 300,000 it seems pretty fair to me. I have to agree that for vehicles that were built to tow this is pretty dumb. If you have a relay, why wouldn't it be plugged in to the top with the rest of them? I blame it on the Germans. For now I'm heading to Vegas with my left brake light on. I just turn the rest of the lights on so it's not so obvious. The left signal still blinks a funny little blink. Thanks for the help guys!
Re: 2004 Dually Trailer Harness [Re: Dave Hall] #2277359
03/27/17 09:21 PM
03/27/17 09:21 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Well mine started giving me problems with 40K miles on it, probably because I live in a State the salts the heck out of the roads. I lived with it until the engine blew at 165K miles and I decided to try and fix it while the engine was out. By then you couldn't buy a new TIPM because everyone else had already had problems with theirs and Chrysler was sold out so I had to get a used one. eyes After the second used unit I finally had all my lights working, then my trans problems kept coming on and I sold the truck at a loss. frown
A-Body's RULE!
Re: 2004 Dually Trailer Harness [Re: Dave Hall] #2277572
03/28/17 09:23 AM
03/28/17 09:23 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The TIPM is more than just a relay/fuse center. It has an internal module that controls body control functions. 3 possibilitys. A: the trailer stop/ts circuit is shorted to a a hot circuit. B: the internal relay is stuck. C: the module control for the left turn signal is commanding the relay on. The #3 possibility is unlikely if the truck turn signal/brake lamp function normally with the trailer disconnected. You could always tap into the tail lamp circuits as wel. This would require a splitter (U-haul is a good source) as your truck has seperate TS and brake lamp circuits.
Doug
Re: 2004 Dually Trailer Harness [Re: Dave Hall] #2277814
03/28/17 04:57 PM
03/28/17 04:57 PM
Cotati, CA
Cotati, CA
Thanks Doug! I knew some good techs would chime in! I have traced the wire all the way back to the TIPM and I can't find anything shorted. The truck functions normally so I have to go with the "B" door. Great idea on the tapping into the tail lamp on that side! Just cap off that yellow wire and run a new one from the tail light! Probably easier than what the guy in the video did. Do you see any potential problems with doing it this way? ie; needing a higher amp fuse or relay on that side?
Re: 2004 Dually Trailer Harness [Re: Dave Hall] #2277924
03/28/17 07:34 PM
03/28/17 07:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The only issue is without a splitter box you will not have a brake lamp on that side (or turn signal). The trailer is one circuit, the truck has separate circuits. Disasembly of the TIPM isn't that bad.
Doug
Re: 2004 Dually Trailer Harness [Re: dvw] #2277968
03/28/17 08:36 PM
03/28/17 08:36 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
If you need a TIPM for parts I still have my original. wave
A-Body's RULE!
Re: 2004 Dually Trailer Harness [Re: Dave Hall] #2277987
03/28/17 09:03 PM
03/28/17 09:03 PM
Cotati, CA
Cotati, CA
Damn I hate to tear into this thing. I use my pickup all the time. I'm heading to Vegas next week so I won't be doing anything soon. Thanks again!
