Re: 468 ci sb- Single plane vs Tunnel ram
[Re: 69 lawndart]
#2269541
03/14/17 07:52 PM
03/14/17 07:52 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
Les I have the same combination with W9's and a TR with two 1000 CFM throttle bodies. It really picked up when I changed from one 1250 CFM Throttle body to two 1000. Feed the animal. what tunnel ram are you running ? and what et/mph did it change
[Re: Ian]
#2269804
03/15/17 03:12 AM
03/15/17 03:12 AM
Posts: 205 Edmonton Alberta, Canada
R3DART
not sure if you will see gains with the t/r was the indy ported ,i think if you port a 772 and converted to yours it will make more power or a sheet metal the rp s move some air 360 cfm just my 2 cents. Ian, my intake is not ported. After a discussion I had with Brett a while back, I was planning on getting rid of my 4150 to 4500 adapter and opening it up for the dominator. But every time I walk into my garage I see that pro dominator tunnel ram sitting there. Seems a shame not to use it if can be made to work well.
[Re: 69 lawndart]
#2269807
03/15/17 03:16 AM
03/15/17 03:16 AM
R3DART
Les I have the same combination with W9's and a TR with two 1000 CFM throttle bodies. It really picked up when I changed from one 1250 CFM Throttle body to two 1000. Feed the animal. Lawndart, is yours a sheet metal TR ?
[Re: R3DART]
#2269843
03/15/17 09:40 AM
03/15/17 09:40 AM
Ian
Victoria, Australia
twins look better lol this is a indy i converted to dom
[Re: Ian]
#2269897
03/15/17 11:48 AM
03/15/17 11:48 AM
Posts: 103 Kansas, Topeka
69 lawndart
Kansas, Topeka
That's a nice looking cast intake.
[Re: 69 lawndart]
#2270154
03/15/17 08:00 PM
03/15/17 08:00 PM
Ian
Victoria, Australia
That's a nice looking cast intake. thank you .nice set up you have ,just keep a eye on your fan have seen a few brake or fly apart ,your hogan intake is way better than any holley t/r .R3DART but i think with some port work the holley may get close to the indy unported and a ported one will give you around 25 hp more,if you are chasing hp then there is only one way to go .up to you my friend
