Nascar truck engine for street strip A body?? #2266221
03/09/17 03:11 PM
03/09/17 03:11 PM
Sarasota, Fl
Scoober Offline OP
Scoober  Offline OP
Sarasota, Fl
Hello All,
I am looking for advice from the engine heads here!! I picked up a Dodge Nascar truck engine, complete less the carb. It was freshened up after running a race at Daytona years ago and sat in a garage sealed tight. It has a dry sump oil system on it. I know very little about dry sump systems at this point, but from what I am reading, this type of system is not used on street/strip cars very much. I want to install it into an A body strip/mostly street car.
My question is whether I should convert the engine to wet sump(which I assume is possible)or go my original route of a quality crate engine and sell the truck engine. Is it too radical an engine for street use?? It is in the 650 to 700hp range. Will swapping the oil systems be involved and expensive?? Are these engine blocks and heads hard to get mounts and headers for?? The heads are W-9's I think??
I got a very good deal on this engine, so I could spend several thousand dollars on the conversion and still be under the cost of a quality crate engine of equal HP.
I am sure I am missing other issues that might be in play here, so please guide me in the smartest direction.
Thank you everybody!!!!
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2266286
03/09/17 05:10 PM
03/09/17 05:10 PM
AndyF Offline
AndyF  Offline
You will need to post pictures before we can answer your question. If it is a NASCAR block then it is probably dry sump only since the block isn't designed for an internal pump. Dry sump works just fine on the street (new Corvettes are dry sump as are most high end European sports cars) but it does take up room. You will most likely need a custom K frame to deal with the dry sump as well as a motor plate for the engine. I doubt that block has any motor mount ears on it unless it is a really old NASCAR engine that still used an OEM type of block.
If you search around the web a little bit you'll find some very cool Mopar cars that have NASCAR engines in them. Lots of work and money to make it happen but they look cool and sound wicked.
I will say that if you're on the internet asking how to do a project like this then you probably don't have the ability to make it happen so a crate engine might be the wise choice. However, if there is a street rod builder in your local area who takes a liking to you then the project could happen. Street rod dudes have been mating weird engine combos together for 50 years and they know how to do most anything.
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2266327
03/09/17 06:22 PM
03/09/17 06:22 PM
Sarasota, Fl
Scoober Offline OP
Scoober  Offline OP
Sarasota, Fl
Thanks AndyF for the reply!! up
I will take and post some pics. I believe there are no mount ears on the block.. I planned on going with a K member change to AlterKation or other replacement.
THX!!!
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2266334
03/09/17 06:28 PM
03/09/17 06:28 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
A board member has one in a Valiant...Maybe he'll see this and chime in... shruggy
...FAFO...
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2266339
03/09/17 06:50 PM
03/09/17 06:50 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Depends what "NASCAR" engine it is. Post a pic of the engine if you want real answers, since you are unsure what it is.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2266347
03/09/17 07:02 PM
03/09/17 07:02 PM
oregon
greendart408 Offline
oregon
I have an ex w8 nascar truck motor, dry sump, I converted the block and the rear main cap to accept a oil pump. All the valley drain backs etc etc. Not for the faint of heart, quite involved to get one going, I'm a machinist so I was able to do it no problem, going to need some skills...... Can be done but you need to want it, if that comes across clearly. I'm days away from running, forcing air in with a f2 on mine. Good luck on your decision.
Re: Nascar truck engine for street strip A body?? [Re: greendart408] #2266360
03/09/17 07:36 PM
03/09/17 07:36 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
My first question would be is it a R3/W8 or R5/P7 based engine?
Alan Jones
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2266461
03/09/17 10:41 PM
03/09/17 10:41 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
having seen picts of greendarts mill he's definitely talented on the machine work side of things. It's like he's a brain surgeon.... and I'm that kid eating mud trying to pound that square peg in the round hole.
waiting for picts OP!!!!
Re: Nascar truck engine for street strip A body?? [Re: greendart408] #2266478
03/09/17 11:01 PM
03/09/17 11:01 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Originally Posted By greendart408
I have an ex w8 nascar truck motor forcing air in with a f2 on mine.
WOW eek Should be fun up
1963 Plymouth Max Wedge
1971 Barracuda
Re: Nascar truck engine for street strip A body?? [Re: LA360] #2266490
03/09/17 11:22 PM
03/09/17 11:22 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
There is also an R6/P8 engine,it is easy to ID as it has a front mount distributor. Seems to be quite a few for sale lately.
RT
Re: Nascar truck engine for street strip A body?? [Re: RTSrunner] #2266639
03/10/17 07:58 AM
03/10/17 07:58 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
RT
Really? Where are they for sale and how much? I doubt they are affordable.
The whole build looks completely different, not just the distributor. It's a piece of cake to tell the difference between all 3. If the OP would just post pics.....
SDG Motorsports
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2266678
03/10/17 11:06 AM
03/10/17 11:06 AM
rpagan Offline
rpagan  Offline
I'm putting one together right now. If you want to PM me your number and a good time to call I may be able answer any questions you may have. I'm just north of New Port Richey.
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2266693
03/10/17 11:42 AM
03/10/17 11:42 AM
Sarasota, Fl
Scoober Offline OP
Scoober  Offline OP
Sarasota, Fl
Thanks again everybody... bow I will post pics over the weekend. Doing some shop re-arranging and the motor is currently buried in the corner.. green
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2266695
03/10/17 11:50 AM
03/10/17 11:50 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
considering there are some street cars out there with A8 builds.... anything is possible.
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2266762
03/10/17 01:46 PM
03/10/17 01:46 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Another option if you can't get the dry sump to work is a wet sump with a single stage external oil pump. I use a Moroso but there are others.
Re: Nascar truck engine for street strip A body?? [Re: 340Cuda] #2266931
03/10/17 06:22 PM
03/10/17 06:22 PM
dogdays Offline
dogdays  Offline
Pros:
oil pan has better ground clearance or can mount engine lower
pump literally vacuums the oil out of the engine
negative pressure in the crankcase lets the crank spin easier
much more highly developed system with up to date ideas
you are replacing the K-frame so you should be able to get a new suspension that the engine fits into
you can put more weight on passenger side (oil tank)
longer between oil changes
Cons
where to mount the large oil tank
more hoses to get in the way
one more belt to buy
probably weighs more
more expensive oil changes
I think I'd look at those street cars with dry sumps and see what the configuration of their oil tanks looks like. There has to be some residence time in the oil tank for air to come out of suspension
R.
Re: Nascar truck engine for street strip A body?? [Re: DemonDust] #2267169
03/11/17 01:25 AM
03/11/17 01:25 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
RT
I saw a listing for a block and a bunch of heads,I think a C/L ad.I looked on ebay after I saw it and there were/are a bunch of blocks(around $1500) and heads there,cranks too.I think there are some parts for sale on here to in the race section.I think all the little stuff will add up a bit even with a $1500ish block to start.
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2267326
03/11/17 12:27 PM
03/11/17 12:27 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
It's going to like a buttload of RMP's I hope your drivetrain can handle being dropped at 6500
Coming soon!!!!
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2268408
03/13/17 12:38 AM
03/13/17 12:38 AM
Sarasota, Fl
Scoober Offline OP
Scoober  Offline OP
Sarasota, Fl
Hey Guys,
I got pics of the engine.. But I can't figure out how to attach them.. I went to the help section, but it isn't clicking... eek
I printed the instructions and will have the workplace geek help me out.... up
Re: Nascar truck engine for street strip A body?? [Re: Scoober] #2268419
03/13/17 12:58 AM
03/13/17 12:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just to keep your mind open.. you could sell
off what you have(if the price was right) and
get a gen 3 to put in.. easier and cheaper
wave
