Re: Nascar truck engine for street strip A body??
[Re: Scoober]
#2266327
03/09/17 06:22 PM
03/09/17 06:22 PM
Posts: 49 Sarasota, Fl
Scoober
Sarasota, Fl
Thanks AndyF for the reply!! I will take and post some pics. I believe there are no mount ears on the block.. I planned on going with a K member change to AlterKation or other replacement. THX!!!
[Re: Scoober]
#2266347
03/09/17 07:02 PM
03/09/17 07:02 PM
Posts: 1,075 oregon
greendart408
oregon
I have an ex w8 nascar truck motor, dry sump, I converted the block and the rear main cap to accept a oil pump. All the valley drain backs etc etc. Not for the faint of heart, quite involved to get one going, I'm a machinist so I was able to do it no problem, going to need some skills...... Can be done but you need to want it, if that comes across clearly. I'm days away from running, forcing air in with a f2 on mine. Good luck on your decision.
[Re: greendart408]
#2266478
03/09/17 11:01 PM
03/09/17 11:01 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have an ex w8 nascar truck motor forcing air in with a f2 on mine. WOW Should be fun
1963 Plymouth Max Wedge 1971 Barracuda
[Re: LA360]
#2266490
03/09/17 11:22 PM
03/09/17 11:22 PM
Posts: 1,882 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
My first question would be is it a R3/W8 or R5/P7 based engine? There is also an R6/P8 engine,it is easy to ID as it has a front mount distributor. Seems to be quite a few for sale lately. RT
[Re: RTSrunner]
#2266639
03/10/17 07:58 AM
03/10/17 07:58 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
My first question would be is it a R3/W8 or R5/P7 based engine? There is also an R6/P8 engine,it is easy to ID as it has a front mount distributor. Seems to be quite a few for sale lately. RT Really? Where are they for sale and how much? I doubt they are affordable. The whole build looks completely different, not just the distributor. It's a piece of cake to tell the difference between all 3. If the OP would just post pics.....
[Re: DemonDust]
#2267169
03/11/17 01:25 AM
03/11/17 01:25 AM
RTSrunner
Pittsburgh,PA
My first question would be is it a R3/W8 or R5/P7 based engine? There is also an R6/P8 engine,it is easy to ID as it has a front mount distributor. Seems to be quite a few for sale lately. RT Really? Where are they for sale and how much? I doubt they are affordable. The whole build looks completely different, not just the distributor. It's a piece of cake to tell the difference between all 3. If the OP would just post pics..... I saw a listing for a block and a bunch of heads,I think a C/L ad.I looked on ebay after I saw it and there were/are a bunch of blocks(around $1500) and heads there,cranks too.I think there are some parts for sale on here to in the race section.I think all the little stuff will add up a bit even with a $1500ish block to start.
[Re: Scoober]
#2268419
03/13/17 12:58 AM
03/13/17 12:58 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Just to keep your mind open.. you could sell off what you have(if the price was right) and get a gen 3 to put in.. easier and cheaper
