Old auto trans faskets #2260120
02/26/17 10:09 PM
02/26/17 10:09 PM
Monroe, LA USA
Carsavior Offline OP
Monroe, LA USA
Looking for the gasket that goes on the cover where the shift cable goes into the tranny on a 65 Chrysler. Any sources?
Re: Old auto trans faskets [Re: Carsavior] #2260557
02/27/17 04:05 PM
02/27/17 04:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There is no gasket on the shift cable but the rubber O ring is .700" OD X .100" thick.
Re: Old auto trans faskets [Re: John_Kunkel] #2262466
03/03/17 01:46 AM
03/03/17 01:46 AM
Monroe, LA USA
Monroe, LA USA
Small aluminum box approximately 2 inch by 5 inch. Bolts to bottom of trans. One cable goes into it. Need the gasket for it.
Re: Old auto trans faskets [Re: Carsavior] #2262517
03/03/17 04:54 AM
03/03/17 04:54 AM
It sounds like someone has put a older cast iron torqueflyte in that car work
Does the cast iron transmission case bolt into the aluminum bell housing?
If so you have a early cast iron tranny in that car, not a 727 like should be in it shruggy scope
Re: Old auto trans faskets [Re: Cab_Burge] #2262521
03/03/17 05:08 AM
03/03/17 05:08 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Cab, I think your forgetting the parking lock housing that were on early 60s TFs. I don't know if you can buy one of those gaskets separate. Probably easier to make one.
LINKY
Re: Old auto trans faskets [Re: 52savoy] #2262705
03/03/17 03:38 PM
03/03/17 03:38 PM
LINKY
Your probably correct on this up
OP, are you looking for that gasket?
Re: Old auto trans faskets [Re: Carsavior] #2262712
03/03/17 03:51 PM
03/03/17 03:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Old auto trans faskets [Re: Carsavior] #2262778
03/03/17 06:39 PM
03/03/17 06:39 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Send me a PM with your name and address and I'll mail one out to you.
Re: Old auto trans faskets [Re: John_Kunkel] #2262854
03/03/17 08:49 PM
03/03/17 08:49 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Originally Posted By John_Kunkel
Park housing gasket.
So that's for the park brake.
I scrapped out a 65 New port a few years back.
I also thought that was the shifter cable.
I have mechanical Aptitude.
I can screw up anything.
