Re: Old auto trans faskets
[Re: Carsavior]
#2260557
02/27/17 04:05 PM
02/27/17 04:05 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There is no gasket on the shift cable but the rubber O ring is .700" OD X .100" thick.
[Re: Carsavior]
#2262517
03/03/17 04:54 AM
03/03/17 04:54 AM
Posts: 43,124 Bend,OR USA
Cab_Burge
It sounds like someone has put a older cast iron torqueflyte in that car Does the cast iron transmission case bolt into the aluminum bell housing? If so you have a early cast iron tranny in that car, not a 727 like should be in it
[Re: Cab_Burge]
#2262521
03/03/17 05:08 AM
03/03/17 05:08 AM
Posts: 4,231 State of retirement
52savoy
State of retirement
It sounds like someone has put a older cast iron torqueflyte in that car Does the cast iron transmission case bolt into the aluminum bell housing? If so you have a early cast iron tranny in that car, not a 727 like should be in it Cab, I think your forgetting the parking lock housing that were on early 60s TFs. I don't know if you can buy one of those gaskets separate. Probably easier to make one. LINKY
[Re: 52savoy]
#2262705
03/03/17 03:38 PM
03/03/17 03:38 PM
Cab_Burge
It sounds like someone has put a older cast iron torqueflyte in that car Does the cast iron transmission case bolt into the aluminum bell housing? If so you have a early cast iron tranny in that car, not a 727 like should be in it Cab, I think your forgetting the parking lock housing that were on early 60s TFs. I don't know if you can buy one of those gaskets separate. Probably easier to make one. LINKY Your probably correct on this OP, are you looking for that gasket?
[Re: John_Kunkel]
#2262854
03/03/17 08:49 PM
03/03/17 08:49 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
So that's for the park brake. I scrapped out a 65 New port a few years back. I also thought that was the shifter cable.
I have mechanical Aptitude. I can screw up anything.
