Where to get shifter cables for early A body #2261486
03/01/17 03:12 AM
03/01/17 03:12 AM
N.E.Ohio
P
Polarabill Offline OP
P
N.E.Ohio
904 is leaking badly where shifter cables enter trans. Does any one make or sell these cables? This is for a 65 valiant
This would be so much easier if I knew what I was doing...
Re: Where to get shifter cables for early A body [Re: Polarabill] #2261492
03/01/17 03:33 AM
03/01/17 03:33 AM
Is it leaking out of the shifter cable sheath or the O rings around the tranny bungs? If the sheath you might be able to fix that with a piece of Viton fuel line hose slipped over the skinny end long enough to cover the bad part of the cable housing and then use screw type hose clamps on each end work shruggy
It has been done that way more than once shruggy
Re: Where to get shifter cables for early A body [Re: Polarabill] #2261518
03/01/17 07:39 AM
03/01/17 07:39 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Imperial Services....
Re: Where to get shifter cables for early A body [Re: Cab_Burge] #2261534
03/01/17 10:47 AM
03/01/17 10:47 AM
N.E.Ohio
P
P
N.E.Ohio
it looks like it leaks where the cable goes into the tranny
Re: Where to get shifter cables for early A body [Re: Kern Dog] #2261535
03/01/17 10:48 AM
03/01/17 10:48 AM
N.E.Ohio
P
P
N.E.Ohio
thanks
Re: Where to get shifter cables for early A body [Re: Polarabill] #2261551
03/01/17 11:37 AM
03/01/17 11:37 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Re: Where to get shifter cables for early A body [Re: Polarabill] #2261577
03/01/17 12:32 PM
03/01/17 12:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There is an oring that seals that and can be replaced.
Don't be the exception.
Re: Where to get shifter cables for early A body [Re: Polarabill] #2261674
03/01/17 03:39 PM
03/01/17 03:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Where to get shifter cables for early A body [Re: John_Kunkel] #2262130
03/02/17 12:13 PM
03/02/17 12:13 PM
moparx Offline
moparx  Offline
i have also installed "marine grade" heat shrink tubing [with the adhesive] on the cable sheath. that guards against leaks getting past the o-rings.
beer
Re: Where to get shifter cables for early A body [Re: moparx] #2262284
03/02/17 07:04 PM
03/02/17 07:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
There are two types of shift cable leaks, either the O ring or tears in the rubber sheath surrounding the cable housing. Heat shrink works fine for damaged sheath (the fluid level in the cable housing is the same as on the dipstick) but is useless for O ring leaks.
Re: Where to get shifter cables for early A body [Re: John_Kunkel] #2262588
03/03/17 12:01 PM
03/03/17 12:01 PM
moparx Offline
moparx  Offline
john, you are correct. i just misspoke, as i was referring to leaks that occur past the o-rings. the o-rings must be in good condition or leaks will develop. i was only referring to a cure for the cable leak. sorry if this mislead anyone.
beer
Re: Where to get shifter cables for early A body [Re: Polarabill] #2262784
03/03/17 06:51 PM
03/03/17 06:51 PM
N.E.Ohio
P
P
N.E.Ohio
Thanks for the tips guys. As soon as the weather breaks again I'll check the O rings to see how they are. I'm guessing they are 50 years old.
