Where to get shifter cables for early A body
#2261486
03/01/17 03:12 AM
03/01/17 03:12 AM
Posts: 2,048 N.E.Ohio
Polarabill
N.E.Ohio
904 is leaking badly where shifter cables enter trans. Does any one make or sell these cables? This is for a 65 valiant
This would be so much easier if I knew what I was doing...
Re: Where to get shifter cables for early A body
[Re: Cab_Burge]
#2261534
03/01/17 10:47 AM
03/01/17 10:47 AM
Polarabill
N.E.Ohio
Is it leaking out of the shifter cable sheath or the O rings around the tranny bungs? If the sheath you might be able to fix that with a piece of Viton fuel line hose slipped over the skinny end long enough to cover the bad part of the cable housing and then use screw type hose clamps on each end It has been done that way more than once it looks like it leaks where the cable goes into the tranny
[Re: Polarabill]
#2261577
03/01/17 12:32 PM
03/01/17 12:32 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
it looks like it leaks where the cable goes into the tranny There is an oring that seals that and can be replaced.
[Re: moparx]
#2262284
03/02/17 07:04 PM
03/02/17 07:04 PM
Posts: 25,871 Rio Linda, CA
John_Kunkel
Rio Linda, CA
There are two types of shift cable leaks, either the O ring or tears in the rubber sheath surrounding the cable housing. Heat shrink works fine for damaged sheath (the fluid level in the cable housing is the same as on the dipstick) but is useless for O ring leaks.
[Re: Polarabill]
#2262784
03/03/17 06:51 PM
03/03/17 06:51 PM
Polarabill
N.E.Ohio
Thanks for the tips guys. As soon as the weather breaks again I'll check the O rings to see how they are. I'm guessing they are 50 years old.
