s anyone ordered the New Trick Flow 270 Heads yet?
#2250569
02/09/17 06:50 PM
02/09/17 06:50 PM
Posts: 1,770 Wethersfield,CT
Ray440
Wethersfield,CT
There are posts on Facebook and For A bodies Only saying they are available. But Summit racing say they are shipping them in March. I just wanted to pass along the info. www.summitracing.com/parts/tfs-6161t784-c01/overview
1969 Plymouth Road Runner 440 auto 2017 Ram 1500 Quad Cab 5.7 Hemi
Re: s anyone ordered the New Trick Flow 270 Heads yet?
[Re: Ray440]
#2250877
02/10/17 03:09 AM
02/10/17 03:09 AM
Posts: 19 Sweden
Cuda_70
Sweden
3 versions (of 4) are available since last week from Summit. Summit TFS-6161 TFS-61617801-C01 1.460" dual valve springs, 270cc intake runners TFS-61617802-C01 1.550" dual valve springs, 270cc intake runners TFS-6161T783-C01 1.550" dual valve springs and titanium retainers,270cc intake runners TFS-6161T784-C01 1.560" dual valve springs and titanium retainers,270cc intake runners
[Re: Ray440]
#2250916
02/10/17 07:22 AM
02/10/17 07:22 AM
Posts: 257 plainwell,michigan
1fastaspen
plainwell,michigan
1st run is shipped and 3-4 weeks on the next shipment is what I was told by trick flow but then again they also told me that the 270cc head was non max wedge port but turns out they are a max wedge port
75 duster 440 in the works
71 pro street cuda
[Re: Ray440]
#2250942
02/10/17 10:13 AM
02/10/17 10:13 AM
Posts: 5,192 CT
GTX MATT
CT
Wait... all this waiting and they want 600 bucks more for a pair of heads that flow 17 CFM more? And flow no different up to .400 lift with a 30 cc bigger port? With the same exhaust port? Really?
[Re: BradH]
#2250975
02/10/17 11:43 AM
02/10/17 11:43 AM
Posts: 1,057 The Great White North
RAMM
Until someone fixes the crappy valve position which opens right into the cylinder wall they can throw all the port size they want at it. Somebody really needs to do a better head and so what if it requires different valve notches in your pistons--look at the success of the Kaase P51. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: Ray440]
#2251001
02/10/17 12:39 PM
02/10/17 12:39 PM
Posts: 14,553 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
$600 more??
I see $380 and $400 more, per pair, depending on which spring package you get.
Still an incredible bargain IMO.
[Re: fast68plymouth]
#2251024
02/10/17 01:08 PM
02/10/17 01:08 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
$600 more??
Still an incredible bargain IMO. Dwayne are those flow #s legit? Seems high for .600 lift? Don
[Re: cudadon]
#2251035
02/10/17 01:23 PM
02/10/17 01:23 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not positive but I think it was Larry Smith in North Carolina posted some pictures of the 270 heads on Facebook yesterday and is going to do some testing and see what they are capable of after some port work.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: cudadon]
#2251046
02/10/17 01:47 PM
02/10/17 01:47 PM
BradH
$600 more??
Still an incredible bargain IMO. Dwayne are those flow #s legit? Seems high for .600 lift? Don TF's advertised intake #s for their MW 270 are very close across the entire lift curve to the standard-port Victors that Dwayne did for me last year. I don't see anything out of line with TF's claims.
[Re: RAMM]
#2251048
02/10/17 01:49 PM
02/10/17 01:49 PM
BradH
Until someone fixes the crappy valve position which opens right into the cylinder wall they can throw all the port size they want at it. Somebody really needs to do a better head and so what if it requires different valve notches in your pistons--look at the success of the Kaase P51. J.Rob I hear ya'...
[Re: Ray440]
#2251057
02/10/17 02:12 PM
02/10/17 02:12 PM
KOS
[Re: cudadon]
#2251101
02/10/17 03:33 PM
02/10/17 03:33 PM
fast68plymouth
So. Burlington, Vt.
$600 more??
Still an incredible bargain IMO. Dwayne are those flow #s legit? Seems high for .600 lift? Don The numbers don't seem out of line, but they're just "numbers" to me until I get the chance to put one on the bench. The advertised numbers for the 240's and the numbers I got weren't that far apart, and I'd expect the same from the 270's.
[Re: pittsburghracer]
#2251176
02/10/17 05:37 PM
02/10/17 05:37 PM
Posts: 20,415 Park Forest, IL
slantzilla
Park Forest, IL
Not positive but I think it was Larry Smith in North Carolina posted some pictures of the 270 heads on Facebook yesterday and is going to do some testing and see what they are capable of after some port work. Saw that too.
[Re: Ray440]
#2251476
02/11/17 07:10 AM
02/11/17 07:10 AM
1fastaspen
plainwell,michigan
Larry is working on a set of the 270cc heads going to be interesting to see how much more is left in these heads
71 pro street cuda
#2252317
02/12/17 02:49 PM
02/12/17 02:49 PM
cudadon
New Lenox IL
$600 more??
Still an incredible bargain IMO. Dwayne are those flow #s legit? Seems high for .600 lift? Don The numbers don't seem out of line, but they're just "numbers" to me until I get the chance to put one on the bench. The advertised numbers for the 240's and the numbers I got weren't that far apart, and I'd expect the same from the 270's. They appear to be better than the MW SR's you did for me? TF has same size int valve, but smaller ex valve. What volume do the MW SRs have? Thanks, Don
