s anyone ordered the New Trick Flow 270 Heads yet? #2250569
02/09/17 07:50 PM
02/09/17 07:50 PM
Wethersfield,CT
Ray440 Offline OP
Ray440  Offline OP
Wethersfield,CT
There are posts on Facebook and For A bodies Only saying they are available. But Summit racing say they are shipping them in March. I just wanted to pass along the info.
www.summitracing.com/parts/tfs-6161t784-c01/overview
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: Ray440] #2250582
02/09/17 08:07 PM
02/09/17 08:07 PM
Zumbrota,MN
als499 Offline
als499  Offline
Zumbrota,MN
A-tech is showing they are ready to ship today.
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: Ray440] #2250877
02/10/17 04:09 AM
02/10/17 04:09 AM
Sweden
Cuda_70 Offline
Cuda_70  Offline
Sweden
3 versions (of 4) are available since last week from Summit.
Summit TFS-6161
TFS-61617801-C01 1.460" dual valve springs, 270cc intake runners
TFS-61617802-C01 1.550" dual valve springs, 270cc intake runners
TFS-6161T783-C01 1.550" dual valve springs and titanium retainers,270cc intake runners
TFS-6161T784-C01 1.560" dual valve springs and titanium retainers,270cc intake runners
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: Ray440] #2250916
02/10/17 08:22 AM
02/10/17 08:22 AM
plainwell,michigan
1fastaspen Offline
1fastaspen  Offline
plainwell,michigan
1st run is shipped and 3-4 weeks on the next shipment is what I was told by trick flow but then again they also told me that the 270cc head was non max wedge port but turns out they are a max wedge port
75 duster 440 in the works
71 pro street cuda
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: Ray440] #2250942
02/10/17 11:13 AM
02/10/17 11:13 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Wait... all this waiting and they want 600 bucks more for a pair of heads that flow 17 CFM more? And flow no different up to .400 lift with a 30 cc bigger port? With the same exhaust port? Really?
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: GTX MATT] #2250964
02/10/17 12:11 PM
02/10/17 12:11 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I noticed the description says raised runners; the pics on Summit do show an intake port configuration like an Indy EZ where it's raised and extended enough to use a valley cover, instead of an OEM-style pan.
The CNC finish is TF's Competition style, not the Street style used with the 240s.
For all the changes, I would have expected higher flow rates. However, TF chose to stay with standard-offset intake rockers, so there is only so much port area available to work with when you have that constraint built into the design.
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: BradH] #2250975
02/10/17 12:43 PM
02/10/17 12:43 PM
The Great White North
RAMM Offline
RAMM  Offline
Until someone fixes the crappy valve position which opens right into the cylinder wall they can throw all the port size they want at it. Somebody really needs to do a better head and so what if it requires different valve notches in your pistons--look at the success of the Kaase P51. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: Ray440] #2250986
02/10/17 01:07 PM
02/10/17 01:07 PM
warren, mich.
dwayne welder Offline
warren, mich.
Correct RAMM 👍👍👍👍👍
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: Ray440] #2251001
02/10/17 01:39 PM
02/10/17 01:39 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
$600 more??
I see $380 and $400 more, per pair, depending on which spring package you get.
Still an incredible bargain IMO.
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: fast68plymouth] #2251024
02/10/17 02:08 PM
02/10/17 02:08 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Originally Posted By fast68plymouth
$600 more??
Dwayne are those flow #s legit? Seems high for .600 lift?
Don
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: cudadon] #2251035
02/10/17 02:23 PM
02/10/17 02:23 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Not positive but I think it was Larry Smith in North Carolina posted some pictures of the 270 heads on Facebook yesterday and is going to do some testing and see what they are capable of after some port work.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: cudadon] #2251046
02/10/17 02:47 PM
02/10/17 02:47 PM
BradH Offline
BradH  Offline
$600 more??
Don
TF's advertised intake #s for their MW 270 are very close across the entire lift curve to the standard-port Victors that Dwayne did for me last year. I don't see anything out of line with TF's claims.
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: RAMM] #2251048
02/10/17 02:49 PM
02/10/17 02:49 PM
BradH Offline
BradH  Offline
I hear ya'...
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: Ray440] #2251057
02/10/17 03:12 PM
02/10/17 03:12 PM
K
KOS Offline
KOS  Offline
K
harland sharp only???
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: KOS] #2251069
02/10/17 03:38 PM
02/10/17 03:38 PM
AndyF Offline
AndyF  Offline
That is just what Trick Flow recommends. Obviously lots of other rocker arms fit (or can be made to fit).
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: cudadon] #2251101
02/10/17 04:33 PM
02/10/17 04:33 PM
So. Burlington, Vt.
So. Burlington, Vt.
$600 more??
Don
The numbers don't seem out of line, but they're just "numbers" to me until I get the chance to put one on the bench.
The advertised numbers for the 240's and the numbers I got weren't that far apart, and I'd expect the same from the 270's.
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: pittsburghracer] #2251176
02/10/17 06:37 PM
02/10/17 06:37 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Saw that too.
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: slantzilla] #2251429
02/11/17 02:25 AM
02/11/17 02:25 AM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Larry Smith opened my 240s up to 249CCs, they flow 370 @700 lift.
It will be interesting to see where the 270s end up, with the design limitations.
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: Ray440] #2251476
02/11/17 08:10 AM
02/11/17 08:10 AM
plainwell,michigan
1fastaspen Offline
1fastaspen  Offline
plainwell,michigan
Larry is working on a set of the 270cc heads going to be interesting to see how much more is left in these heads
71 pro street cuda
Re: s anyone ordered the New Trick Flow 270 Heads yet? [Re: fast68plymouth] #2252317
02/12/17 03:49 PM
02/12/17 03:49 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
$600 more??
Don
They appear to be better than the MW SR's you did for me?
TF has same size int valve, but smaller ex valve.
What volume do the MW SRs have?
Thanks, Don
