Page 1 of 5 1 2 3 4 5
Harland sharp or T+D rockers for 440-1 heads... #2248156
02/06/17 12:02 AM
02/06/17 12:02 AM
merrill, wisconsin
V
voigtspeed Offline OP
V
merrill, wisconsin
What rockers do you like the best and why ?
Do not want to go with the cost of jessel so it is T+D or Harland sharp.
ACCELERATION SPECIALIST
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2248176
02/06/17 12:21 AM
02/06/17 12:21 AM
Washington
madscientist Offline
Washington
T&D with a bushing, not the bearing.
They'll make them, you just have to ask.
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: madscientist] #2248178
02/06/17 12:24 AM
02/06/17 12:24 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have both and have had zero issues with either sets and I love the bearings in both
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: madscientist] #2248189
02/06/17 12:37 AM
02/06/17 12:37 AM
Howell,MI
Moparpoor Offline
Moparpoor  Offline
Howell,MI
Love my T&D rockers. Why the bushing? I run the bearings
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2248235
02/06/17 01:49 AM
02/06/17 01:49 AM
Are you wanting to buy the single shaft systems from both? If so either one will work, I've had and used both up
I have two motors now with Harland Sharp 1.6 ratio and one set of heads with a set of T&D single shaft system with 1.7 ratio and another untested motor with Jesel 1.55 ratio paired shaft system on it shruggy
The motor with the Jesel rockers rotate a lot easier once broken away than any other motor I have built or tested work scope
I am gathering parts now for a all out go fast motor with B1-MC heads and I will probally buy a set of the stainless steel(chrome moly maybe?) T&D 1.7 ratio paired rocker arm set up from them for this motor twocents
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2248260
02/06/17 02:19 AM
02/06/17 02:19 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Unless the HS setup is a lot less expensive and there's a budget issue, IMO the T&D is a better designed and machined rocker.
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2248317
02/06/17 08:30 AM
02/06/17 08:30 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The T&D paired are the nicest rocker system I've ever used. Nice to be able to remove them a pair at time if needed. In my experience they will wear the shaft before they hurt a bearing. I replaced the bearings in mine last year. I have no idea how many passes they had before me but I'll bet they were somewhere around 1000. Cost $96 to replace all 32 bearings. All looked and felt fine. I had 3 shaft that showed brinelling. They were $25 a piece.
Doug
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: Moparpoor] #2248459
02/06/17 02:07 PM
02/06/17 02:07 PM
Washington
Washington
The short answer is never run a needle bearing on a reciprocating shaft. GM had a system so [censored] that the needle bearing was actually a step up. And the industry followed right along and the rest of us get the same garbage.
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2248464
02/06/17 02:15 PM
02/06/17 02:15 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
If you're going to run springs that are larger than about 1.580, and installed heights taller than about 1.950....... And the T&D system you're considering is the "single shaft" set-up, then you'll more than likely have to do some relieving of the rockers to clear the springs/retainers.
The HS rockers clear 1.625 springs with no issues.
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: fast68plymouth] #2248492
02/06/17 02:46 PM
02/06/17 02:46 PM
PA.
"Little"John
"Little"John
PA.
If I remember right Harland Sharp will also clearance the rockers for more if asked to do so.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2248592
02/06/17 05:03 PM
02/06/17 05:03 PM
AndyF Offline
AndyF  Offline
T&D will do a spring relief on the rocker arm as an option. I had that done on the T&D rockers for my Trick Flow heads.
I've used both T&D and Harland and there isn't any power difference between them. T&D rockers are smaller and lighter and work with pushrod oiling. The Harland rockers are big and beefy and designed to work with shaft oiling.
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2248732
02/06/17 09:46 PM
02/06/17 09:46 PM
K
KOS Offline
KOS  Offline
K
T+D hands down............ive broke HS with a solid flat tappet never any breakage with T+Ds
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2248766
02/06/17 10:24 PM
02/06/17 10:24 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I have both and did break a HS once. It took about 700 runs though. I bought the T&D's for my -1 setup and haven't had an issue in three years. The LSM tool is golden for proper torque and adjustment.
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2248793
02/06/17 10:58 PM
02/06/17 10:58 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Harland Sharp can be ordered with pushrod oiling and cup adjuster as an option at no extra charge. Just remember the HS do not come with mounting bolts or studs. T&D come with all mounting hardware. Best price for HS was found thru Don at FBO.
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: mopar dave] #2248877
02/07/17 01:09 AM
02/07/17 01:09 AM
merrill, wisconsin
V
V
merrill, wisconsin
Thanks for all the input looking for the best in my budget regretfully paired rockers may be a little out of reach right now.
I was leaning toward T+D I have heard good about them I have also had good luck with harland sharp but never used them on 440-1 heads.
Thanks for the heads up on spring diameter. How they fit clearance and geometry wise was another question....
Now to price them.
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2248956
02/07/17 03:45 AM
02/07/17 03:45 AM
I've owned and raced both T&D and Harland Sharp single shafts set ups on Indy heads, I'll buy another set of Harland Sharps for my next single shaft Indy headed motor build up
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: voigtspeed] #2249068
02/07/17 01:38 PM
02/07/17 01:38 PM
Washington
Washington
As was posted on another site....
Quote "with all the steel rockers available today, why would anyone run aluminum?"
I'd also add why would any one run needle bearings. They are so 1977.
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: madscientist] #2249071
02/07/17 01:45 PM
02/07/17 01:45 PM
So. Burlington, Vt.
So. Burlington, Vt.
And which bushed steel rocker system do you recommend to use on the OP's Indy 440-1 heads?
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: fast68plymouth] #2249108
02/07/17 02:48 PM
02/07/17 02:48 PM
Washington
Washington
He is probably stuck with aluminum but he could at least use a bushing instead of needle bearings.
I'd be surprised if Jesel didn't have something.
This is why no one runs chryslers. If someone made a steel rocker, would any one buy it? I doubt it. When I begged for a set of Norris stainless rockers people made fun of me.
Aluminum was only good for the manufacturers.
So, my point should have been if I ever do another race car, it will have other than a Chrysler in it. You can only cobble junk along so much and then you just say [censored] it.
Re: Harland sharp or T+D rockers for 440-1 heads... [Re: madscientist] #2249141
02/07/17 03:46 PM
02/07/17 03:46 PM
PA.
"Little"John
"Little"John
PA.
No one runs Mopars. Give me a break and come to Ohio or Pennsylvania and see how many Mopars run at our tracks. Lol. And we run the crap out of our aluminum roller bearing lifters. 40 years and never broke an aluminum roller bearing rocker but I don't run crap either. Harland Sharp or t&d rockers for me
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
