AAR T/A Ground Cable (maybe others)
#2247838
02/05/17 04:41 PM
02/05/17 04:41 PM
Posts: 768 Dry Heat AZ
AAR#2
Dry Heat AZ
Looking for a little help with the size and shape
1) Appears from the photo attached (originally posted by Barry) some time back the rubber block on the end of the cable is a "D" shape?? Can someone with an original confirm?
2) What is the length, width, and depth (if D shape, diameter with and without the flat)
3) Also looking to get the negative cable Dia.
Thanks in advance
Edited to remove the pic
Re: AAR T/A Ground Cable (maybe others)
[Re: Alaskan_TA]
#2247947
02/05/17 07:11 PM
02/05/17 07:11 PM
Posts: 18,157 Mass
DAYCLONA
Mass
You may want to do some research on posting copyrighted images without permission. ;-)
I agree, I always do that... Copyright Fair Use Doctrine Act
[Re: AAR#2]
#2248011
02/05/17 08:47 PM
02/05/17 08:47 PM
Posts: 29,652 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Thank you. Email when you can & I can get some other photos for you.
[Re: AAR#2]
#2248056
02/05/17 10:02 PM
02/05/17 10:02 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
SO is the rubber actually formed in a D or does it form that way over time due to the way it is bolted to the head and the heat or is does it form that way due to the lug/terminal that is crimped on the wire have a flat back with the crimping arms creating the circular part?
Careful, your character's showing!
[Re: AAR#2]
#2249294
02/07/17 08:33 PM
02/07/17 08:33 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Let me try this another way,
Anyone with pics of survivor AAR's or T/A's that can show the connection of the negative cable to the block, please post photos. Hopefully these pics will substantiate the rubber insulator block on the negative line, then we can address dimensions
Thanks I got this pic off the "internet" of an original maybe it helps?
[Re: AAR#2]
#2252058
02/12/17 03:48 AM
02/12/17 03:48 AM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
Well it's nice to see that nothing has changed sense I've been gone. Wow.
The photo above is correct for a T/A and the bolt is correct as well. I had the same on my 32k mile T/A. Also note the lack of overspray orange paint on it as well.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
