Page 3 of 4 1 2 3 4
Re: SB heads [Re: Porter67] #2233503
01/13/17 02:29 PM
01/13/17 02:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can see the issue in this pic.. looks like
it clears.. but its CLOSE and it did leak
wave
Re: SB heads [Re: RapidRobert] #2233590
01/13/17 05:09 PM
01/13/17 05:09 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By RapidRobert
You also need guides, Chevy will work but a little wide, about the cut off grinding wheel width, then hardened push rods for the guides, they make a 3/8 stud with a 5/16 thread. Had all his sorted out then just bought the factory kit.
Is there a complete kit of these parts or do you piece it together with the level of quality that you need for your particular app?
Back in about 07-08 I was finishing up my Magnum 360-380 build and Chrysler had the complete kit, 1.7 roller rockers, springs and retainers, guides, pushrods, studs, might have been a few other things too. On sale for like $275 if I remember right, was over $500. Not sure if still available now. I had ported the heads using the factory templates and cut the guides for the pc seals. Now that I got my Kwic-Way valve grinder I'll remove the heads and do some more work around the valve. Engine is still on the stand waiting for the Duster to be finished. I know, I know, too many projects. Should be a nice little engine making some power, It has the RT cam in it now but I might just use the .501 cam instead. Like I said the Chevy guides will work but need to be narrower, then you need cm pushrods. I might change back to the good bee hive springs also, Pac I think.
Re: SB heads [Re: Racer33] #2233655
01/13/17 07:03 PM
01/13/17 07:03 PM
Washington
madscientist Offline
Washington
There is no such thing as a Chevy guide. Guides are separated by O.D., I.D., and O.A.L.
You can buy a box of 1000 .500 X .340 X 3.125 guides and put them in any head you can ream to .500
You can buy the same guide with a .308 hole or a .375 hole.
Re: SB heads [Re: madscientist] #2233661
01/13/17 07:06 PM
01/13/17 07:06 PM
Norfolk, NE
Racer33 Offline OP
Racer33  Offline OP
Norfolk, NE
Think they meant guide plates.
Re: SB heads [Re: Racer33] #2233687
01/13/17 07:55 PM
01/13/17 07:55 PM
Washington
Washington
Ok. Seems a guide and guide plate are two different things but we abbreviate the [censored] out of everything anymore so I get left in the dust by the txt crowd.
Re: SB heads [Re: Racer33] #2233737
01/13/17 09:46 PM
01/13/17 09:46 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thank you, got a little ahead of myself, thinking and writing at the same time. To the other guy, calm down its not the end of the world, just ask, I'll try to explain what I meant.
Re: SB heads [Re: cudaman1969] #2233791
01/13/17 10:53 PM
01/13/17 10:53 PM
Washington
Washington
I'm not excited. You said more than once Chevy guides.
Jesus.
Re: SB heads [Re: madscientist] #2233804
01/13/17 11:14 PM
01/13/17 11:14 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Jesus.
Also said "hardened push rods for the guides" don't think anyone puts a push rod in a valve guide.
Muhammad
Re: SB heads [Re: cudaman1969] #2233805
01/13/17 11:15 PM
01/13/17 11:15 PM
Washington
Washington
Jesus.
Muhammad
Okeedookee.
Allah.
Re: SB heads [Re: madscientist] #2233950
01/14/17 11:37 AM
01/14/17 11:37 AM
Madison, Wisconsin
chrisnben Offline
chrisnben  Offline
Madison, Wisconsin
to the OP- since you already have the crosswind dual bolt intake, I'd recommend the Indy magnum (MA-X) heads with 2.02 valves. $1150 complete with .525 springs. All you would need is stock magnum rocker gear at that .500 lift range- not expensive. Plus, they have dual drilled exhaust bolt holes for W2 headers. My 2 cents....
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: SB heads [Re: Racer33] #2234037
01/14/17 03:25 PM
01/14/17 03:25 PM
Earth
Rob C Offline
Rob C  Offline
Earth
In reguardless to W2 intake manifold height, I have a Holley Street Dominator & a M1.
............. M1 --- H, St.D
Front .... 4/5-8 .... 4-11/16
Rear ..... 5-11/16 = both intakes
Having issues adding photos with the I-phone.
Re: SB heads [Re: Rob C] #2234048
01/14/17 03:51 PM
01/14/17 03:51 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Get the " Photo Resizer Lite" app, allows the photo to be downsized to load onto these posts
Re: SB heads [Re: Porter67] #2245161
02/01/17 05:46 AM
02/01/17 05:46 AM
Illinois, USA
jeff1974 Offline
jeff1974  Offline
Illinois, USA
EV2.. The W2 Street dominator looks like a Edelbrock Performer RPM for a 340, but with W2 oval intake ports. Mine is gasket matched to my Heads. Is is a single plane manifold though.
Re: SB heads [Re: jeff1974] #2245807
02/02/17 11:10 AM
02/02/17 11:10 AM
Locomotion Offline
Locomotion  Offline
You may have mis-typed: The W-2 Holley Street Dominator is the same as the Holley Strip Dominator, except it's not "air-gapped" because of the water passage.
Besides custom intakes, I can't think of anyone at the moment who made an aluminum dual plane for W-2s. But Mopar did have a cast iron W-2 dual plane for a short time, probably for certain circle track rules.
Re: SB heads [Re: Racer33] #2245843
02/02/17 12:48 PM
02/02/17 12:48 PM
P
Porter67 Offline
Porter67  Offline
P
I think I have a new (old) mopar dual w2 intake, let me look.
IIRC it sits very low.
Yes the intake on the top of this pile is a mopar al dual plane single four for the W2....
I cam measure it if im told where to pull from.
I think I have almost every w2 intake made by the major parts guys over the years (ive got like 10 or so) so I can measure about
Re: SB heads [Re: Porter67] #2245848
02/02/17 12:59 PM
02/02/17 12:59 PM
Norfolk, NE
Racer33 Offline OP
Racer33  Offline OP
Norfolk, NE
I seen that intake on the Jegs website. If you get a minute could you measure the height of the carb mounting pad?
Re: SB heads [Re: Racer33] #2245852
02/02/17 01:08 PM
02/02/17 01:08 PM
P
Porter67 Offline
Porter67  Offline
P
I will be in my parts shed sat. am and will measure it for you.
The center intake here in this pic is my old strip dom. intake next to the mopar.
Re: SB heads [Re: Porter67] #2245854
02/02/17 01:10 PM
02/02/17 01:10 PM
Norfolk, NE
Racer33 Offline OP
Racer33  Offline OP
Norfolk, NE
Look at all them small block parts. Thanks for the help
Re: SB heads [Re: Racer33] #2245861
02/02/17 01:23 PM
02/02/17 01:23 PM
P
Porter67 Offline
Porter67  Offline
P
These pics will make the w2 guys nt=uts tighten, not aot of these headers left out there. I bought two sets when hooker dumped them all, I think thats how i got them.
They are A body and im not sure I can ever use them, but they look nice.
One day I might build a good W2 motor.
Re: SB heads [Re: Porter67] #2245863
02/02/17 01:26 PM
02/02/17 01:26 PM
Washington
Washington
Hey, do you want to sell that Pro Dominator? Do you have a second one you want to get rid of?
If so, IM INTERESTED.
PM me and maybe we can make a deal.
Page 3 of 4 1 2 3 4
