Re: harland sharp stud kit
[Re: mopar dave]
#2240618
01/24/17 08:30 PM
01/24/17 08:30 PM
Posts: 1,030 ohio
67mprfan
ohio
I bought the Hughes brand take everyone advice and measure to find the lengths you need
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: mopar dave]
#2240708
01/24/17 11:09 PM
01/24/17 11:09 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
This is the one Trick flow lists. I think it is ARP hardware, I'll have to look in the garage. I ordered these for the Trickflow heads with the recommended HS rockers, but have not started putting that engine together yet. https://www.summitracing.com/parts/tfs-61600613Sorry, Just noticed you said Victor head, not trick flow.. I'll have to look at what I ordered for the Victor heads, I think the two (per side, 4 total) long studs were either 3-1/4" or 3-1/2", and I know the three short (per side) studs were 3" because that is the one I broke (Dorman Grade 8) when summit did not list the 3" long ARP studs. I think these were on the longer side to make installing the shafts easier, but may need a taller valve cover. ARP 12-point 3/8"x24 nuts: https://www.summitracing.com/parts/arp-300-8332ARP 3" long 3/8" stud: https://www.summitracing.com/parts/arp-aj3000-5b/overview/ARP 3-1/4" long 3/8" stud: https://www.summitracing.com/parts/arp-aj3250-1b/overview/ARP 3-1/2" long 3/8" stud: https://www.summitracing.com/parts/arp-aj3500-1b/overview/
[Re: mopar dave]
#2240760
01/25/17 12:21 AM
01/25/17 12:21 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
some of the 5 studs are longer if you want to stud all 5 holdowns but my heads only use 2 studs,3 bolts
[Re: mopar dave]
#2240969
01/25/17 12:32 PM
01/25/17 12:32 PM
Clanton
northern,Ohio,USA
The studs are 3 1/4" long,The fine,course threads are 3/4" long so 3/4" of threads into the head.
