harland sharp stud kit #2240480
01/24/17 04:29 PM
01/24/17 04:29 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
any idea what stud kit the Harland sharp rocker kit for victor head takes or if there is one available? Directions say to use your existing bolts, I have none.
Re: harland sharp stud kit [Re: mopar dave] #2240507
01/24/17 05:24 PM
01/24/17 05:24 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Call ARP, they'll know exactly what you need.
Re: harland sharp stud kit [Re: mopar dave] #2240508
01/24/17 05:25 PM
01/24/17 05:25 PM
I would mock up the rocker shafts on the heads and use a dial caliper to determine each hole depth from the hold downs and go from there. I have Harland Sharps 1.6 on my Eddy Victor M.W. heads and I'm almost positive I used several different lengths ARP 3/8 studs to mount them shruggy Make sure you have at least 3/8 thread engagement on the stud in the head, I bottomed mine out and then use a harden 3/8 washer on the hold downs between the nut and the hold downs up
Re: harland sharp stud kit [Re: Cab_Burge] #2240578
01/24/17 07:11 PM
01/24/17 07:11 PM
Mt Morris Michigan
Mt Morris Michigan
Harland sharp didnt have anything and said same as you they thought the studs would be different lenths.
Re: harland sharp stud kit [Re: mopar dave] #2240599
01/24/17 07:46 PM
01/24/17 07:46 PM
AndyF Offline
AndyF  Offline
Figure out what length you need and then buy them from Summit. I don't know of anyone makes a stud kit with ARP hardware. Hughes sells rocker arm stud kits but I don't think they use ARP parts.
Re: harland sharp stud kit [Re: mopar dave] #2240618
01/24/17 08:30 PM
01/24/17 08:30 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I bought the Hughes brand take everyone advice and measure to find the lengths you need
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: harland sharp stud kit [Re: 67mprfan] #2240622
01/24/17 08:36 PM
01/24/17 08:36 PM
Mt Morris Michigan
Mt Morris Michigan
Ok i will do that. HS suggested calling edelbrock as well to see what they have or what i need.
Re: harland sharp stud kit [Re: mopar dave] #2240644
01/24/17 09:17 PM
01/24/17 09:17 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I can measure my studs tomorrow if you like,lmk.
Re: harland sharp stud kit [Re: Clanton] #2240654
01/24/17 09:36 PM
01/24/17 09:36 PM
Mt Morris Michigan
Mt Morris Michigan
Sure, if its not a problem. The engine is at my fathers 80 miles from me.
Re: harland sharp stud kit [Re: mopar dave] #2240655
01/24/17 09:40 PM
01/24/17 09:40 PM
indy
E
eds dart Offline
eds dart  Offline
E
indy
am going thru the same issue. the hughes stud kit does use ARP hardware. I feel the thread engagement is inadequate. for maximum stud strength thread engagement must be at least stud diameter. these victor heads have had problems with splitting the stands. hughes offers an upgrade on rocker stand bolts where they lengthen the helicoil inserts in the head. problem is the studs don't allow for the deeper thread engagement. I have talked to ARP to see if they will offer studs with the longer threads, they said they have received request for this but had no plans to actually make some. don't have a solution yet
Re: harland sharp stud kit [Re: mopar dave] #2240667
01/24/17 09:51 PM
01/24/17 09:51 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
No problem at all. I have M.E.Martin fasteners by me and also Macho tool that carry Grade 8 studs so maybe check in your area.
Re: harland sharp stud kit [Re: Clanton] #2240680
01/24/17 10:22 PM
01/24/17 10:22 PM
Mt Morris Michigan
Mt Morris Michigan
I have a fastener shop right down the road.
Re: harland sharp stud kit [Re: mopar dave] #2240708
01/24/17 11:09 PM
01/24/17 11:09 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
This is the one Trick flow lists. I think it is ARP hardware, I'll have to look in the garage. I ordered these for the Trickflow heads with the recommended HS rockers, but have not started putting that engine together yet.
https://www.summitracing.com/parts/tfs-61600613
Sorry, Just noticed you said Victor head, not trick flow..
I'll have to look at what I ordered for the Victor heads, I think the two (per side, 4 total) long studs were either 3-1/4" or 3-1/2", and I know the three short (per side) studs were 3" because that is the one I broke (Dorman Grade 8) when summit did not list the 3" long ARP studs. I think these were on the longer side to make installing the shafts easier, but may need a taller valve cover.
ARP 12-point 3/8"x24 nuts:
https://www.summitracing.com/parts/arp-300-8332
ARP 3" long 3/8" stud:
https://www.summitracing.com/parts/arp-aj3000-5b/overview/
ARP 3-1/4" long 3/8" stud:
https://www.summitracing.com/parts/arp-aj3250-1b/overview/
ARP 3-1/2" long 3/8" stud:
https://www.summitracing.com/parts/arp-aj3500-1b/overview/
Re: harland sharp stud kit [Re: 451Mopar] #2240731
01/24/17 11:37 PM
01/24/17 11:37 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks for that info. Will be helpful. Once i get the exact measures from clanton i will go from there.
Re: harland sharp stud kit [Re: mopar dave] #2240733
01/24/17 11:39 PM
01/24/17 11:39 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I just looked at the Trick flow kit, and all the studs are 2-1/2" long, no short/long, but they changed the location of the shaft oiling hole in their heads.
I also just recalled that I am using the aluminum max wedge style shaft hold downs on my victor heads (after milling off the original stands), so that is why my rocker hold down studs would be longer than if using the standard HS hold downs.
Re: harland sharp stud kit [Re: mopar dave] #2240760
01/25/17 12:21 AM
01/25/17 12:21 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
some of the 5 studs are longer if you want to stud all 5 holdowns but my heads only use 2 studs,3 bolts
Re: harland sharp stud kit [Re: Clanton] #2240770
01/25/17 12:37 AM
01/25/17 12:37 AM
Mt Morris Michigan
Mt Morris Michigan
Maybe i should just order stock replace and go from there.
Re: harland sharp stud kit [Re: mopar dave] #2240969
01/25/17 12:32 PM
01/25/17 12:32 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The studs are 3 1/4" long,The fine,course threads are 3/4" long so 3/4" of threads into the head.
Re: harland sharp stud kit [Re: Clanton] #2240995
01/25/17 01:29 PM
01/25/17 01:29 PM
Rogue River, OR
Jeremiah Online work
Jeremiah  Online Work
Rogue River, OR
I used 3.5" studs with 1" of thread on each end. They came from McMaster-Carr.
Re: harland sharp stud kit [Re: Clanton] #2241059
01/25/17 03:50 PM
01/25/17 03:50 PM
Mt Morris Michigan
Mt Morris Michigan
Ok, so i can order all 10 studs 3 1/4 - 3 1/2? Thanks guys
