Best dual plane for my Magnum 5.9? #2234583
01/15/17 12:56 PM
01/15/17 12:56 PM
gregsdart Offline OP
I plan on putting the following cam in a boneyard 5.9 Magnum engine, for my street dart. 279 duration, 225/225/106 @ .050 with .480 lift. There are different runner sizes available from what I here, with the Edelbrock airgap being the biggest, and the Pro products ( chinese knockoff) being the smallest. I want lots of torque in the 2500 to 4000 area because the converter will be a fairly tight street unit,(2400?) with the car being primarily a street car.Has anyone done any back to back comparisons on these, dyno or drag strip tests, and what were the conditions like stall and traction?
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2234762
01/15/17 05:04 PM
01/15/17 05:04 PM
Locomotion Offline
Locomotion  Offline
I have no experience with these, but....
Trust in quality may be a concern with Pro Products. I would have thought that port size would be similar because of it being an Air Gap "copy". There still is a M-1 dual plane from Mopar for smaller ports than the Edelbrocks.
http://www.manciniracing.com/mopduelplanm.html
Maybe to help make an educated choice, search to see if there are any dyno numbers using those intakes in LA applications. The HP/torque curve numbers should be similar to their Magnum counterparts.
Any concerns using an Air Gap style without heat crossover in the winter months?
Re: Best dual plane for my Magnum 5.9? [Re: Locomotion] #2234773
01/15/17 05:22 PM
01/15/17 05:22 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Didn't Dulcich (sp?) do a intake comparison for small blocks? I read it in print somewhere and IIRC, the Eddy Air Gap was the overall champ.
Re: Best dual plane for my Magnum 5.9? [Re: cudadoug] #2234787
01/15/17 05:48 PM
01/15/17 05:48 PM
Locomotion Offline
Locomotion  Offline
Thanks, I forgot about that one.
Small block Mopar dyno tests. LA
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2234849
01/15/17 07:06 PM
01/15/17 07:06 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
If your going to street use go "Street Dominator" vs "Strip Dominator" The inside of these manifolds are exactly the same but the street version has water under it and the strip unit does not.
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2234911
01/15/17 09:10 PM
01/15/17 09:10 PM
Locomotion Offline
Locomotion  Offline
Blucuda413, You just reminded me that the Magnum heads don't have a heat crossover! I forgot that in an earlier post. frown
But as far as internal passages, the "Street vs Strip" Dominators, they are only the same on the W-2 versions. For standard beads, Edelbrock RPM with and RPM Air-Gap are the same internally.
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2234914
01/15/17 09:15 PM
01/15/17 09:15 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Myron, I didn't even think about that because the 2 I compared were W2 versions. Thanks for bringing that out.
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2234920
01/15/17 09:27 PM
01/15/17 09:27 PM
crabman173
crabman173
There is a pretty big diff in runner volume on the eddy vs the China deal air gaps -- I measured it on a SBC one time --can't remember but is was a lot--guessing that the Mopar version is similar--the runner cross sections and overall volume was lots smaller on the china job--I can't see how you would be giving up much Tq with the eddy--it would be my choice
If you have both maybe tape them up and CC--hey bet you can see the diff with a tea pitcher and won't need a burret LOL
Thinking small carb may be helpful vs. a 750
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2234933
01/15/17 10:05 PM
01/15/17 10:05 PM
It is looking like the Eddy AirGap is the better choice at this point. I notice on Dulsich's dyno results it isn't far behind at 3,000 and is up as much as 20 hp mid range,and 24 hp up top, although that is with a bigger cam than I have,and better heads than I plan on at this point.
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2235668
01/16/17 11:12 PM
01/16/17 11:12 PM
Gainesville Fl
mphsmitch Offline
mphsmitch  Offline
Gainesville Fl
For what its worth Ive had both of the Crosswind and the Air Gap intakes on my truck when it had the stock bottom end 360 magnum in it. There was no difference in ET at the track.
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2235754
01/17/17 12:37 AM
01/17/17 12:37 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I have a professional products dual plane on my 318 magnum.
Works good.
Best results so far in my signature. My cam is 231/238@50
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2235776
01/17/17 01:07 AM
01/17/17 01:07 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Not to hijack, but B3442W5 please tell us more about your combo. That et in your sig is impressive!!
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Best dual plane for my Magnum 5.9? [Re: 71yelladustr] #2235811
01/17/17 02:02 AM
01/17/17 02:02 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
It's an engine masters build.
10.44 compression. Ported magnum Rt heads. 950 carb, aforementioned hydraulic cam.
Diamond slugs, scat rods, trick lightened 340 crank. 30 over 318 for 323 cubes.
Cheapie 1/5 8 headers, 904, tight 8 inch converter, 28 inch radial with 4.10 gear. Shift it at 6200, traps about 6. Could use a little more gear but I drive it everywhere.
All steel car, 310 pound driver. Nice attention to detail on the short block build, several oiling mods, and rocker shaft upgrades.
But, she has a dinky cam and not much compression, think there is still more.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2236195
01/17/17 06:46 PM
01/17/17 06:46 PM
Thanks to all who gave feedback😀 any more info that would relate to this build is welcome!!
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2236644
01/18/17 12:47 PM
01/18/17 12:47 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Don't use the stock magnum valve springs, barely good enough for the stock cam, then the two piece valves are at risk...Replace the timing chain too.
Maybe you know all this.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2236677
01/18/17 01:55 PM
01/18/17 01:55 PM
Thanks Adobe. I will check with hughes when i oder the springs to see about the stock valves.
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2236682
01/18/17 02:03 PM
01/18/17 02:03 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Whatever you do do NOT remove the heads!
Youll only find tons of cracks in the valve seats and want to replace them...
Dont ask me how i know:-)
It sucks as the magnum heads look so much better than la heads.
Im positive a very small amount of porting/clean up will make them flow very well.
But they all seem to have cracks and throwing time and money on cracked heads is hard to motivate.
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2236687
01/18/17 02:11 PM
01/18/17 02:11 PM
If i do pull them and they need work it will be time for a set of EQs. The value will be there when i sell the motor,if that happens.
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2236707
01/18/17 02:37 PM
01/18/17 02:37 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Thats what i ordered from hughes. Value is good but it cracked my budget.
Re: Best dual plane for my Magnum 5.9? [Re: gregsdart] #2236756
01/18/17 04:04 PM
01/18/17 04:04 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
If cracks make you loose sleep and you are gonna pull the heads have the EQs ready, your heads are cracked. If you have seen thousands of these heads running just fine with cracks in them like I have don't worry about it.
Also I have built tons of these engines with bigger cams than that that see daily use under severe conditions and never seen a stock valve fail except the ocasional burnt valve when nearing 300,000 miles. I am currently running .575 lift and 222@.050 duration 12 to 1 compression in my truck with the stock valves plenty of 6500 RPM blasts and no issues.
