Best dual plane for my Magnum 5.9?
#2234583
01/15/17 12:56 PM
01/15/17 12:56 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I plan on putting the following cam in a boneyard 5.9 Magnum engine, for my street dart. 279 duration, 225/225/106 @ .050 with .480 lift. There are different runner sizes available from what I here, with the Edelbrock airgap being the biggest, and the Pro products ( chinese knockoff) being the smallest. I want lots of torque in the 2500 to 4000 area because the converter will be a fairly tight street unit,(2400?) with the car being primarily a street car.Has anyone done any back to back comparisons on these, dyno or drag strip tests, and what were the conditions like stall and traction?
Re: Best dual plane for my Magnum 5.9?
[Re: gregsdart]
#2234762
01/15/17 05:04 PM
01/15/17 05:04 PM
Posts: 5,894 Florida
Locomotion
I have no experience with these, but.... Trust in quality may be a concern with Pro Products. I would have thought that port size would be similar because of it being an Air Gap "copy". There still is a M-1 dual plane from Mopar for smaller ports than the Edelbrocks. http://www.manciniracing.com/mopduelplanm.htmlMaybe to help make an educated choice, search to see if there are any dyno numbers using those intakes in LA applications. The HP/torque curve numbers should be similar to their Magnum counterparts. Any concerns using an Air Gap style without heat crossover in the winter months?
[Re: cudadoug]
#2234787
01/15/17 05:48 PM
01/15/17 05:48 PM
Locomotion
Didn't Dulcich (sp?) do a intake comparison for small blocks? I read it in print somewhere and IIRC, the Eddy Air Gap was the overall champ. Thanks, I forgot about that one. Small block Mopar dyno tests. LA
[Re: gregsdart]
#2234920
01/15/17 09:27 PM
01/15/17 09:27 PM
crabman173
crabman173
There is a pretty big diff in runner volume on the eddy vs the China deal air gaps -- I measured it on a SBC one time --can't remember but is was a lot--guessing that the Mopar version is similar--the runner cross sections and overall volume was lots smaller on the china job--I can't see how you would be giving up much Tq with the eddy--it would be my choice If you have both maybe tape them up and CC--hey bet you can see the diff with a tea pitcher and won't need a burret LOL Thinking small carb may be helpful vs. a 750
[Re: gregsdart]
#2234933
01/15/17 10:05 PM
01/15/17 10:05 PM
gregsdart
It is looking like the Eddy AirGap is the better choice at this point. I notice on Dulsich's dyno results it isn't far behind at 3,000 and is up as much as 20 hp mid range,and 24 hp up top, although that is with a bigger cam than I have,and better heads than I plan on at this point.
[Re: gregsdart]
#2235668
01/16/17 11:12 PM
01/16/17 11:12 PM
Posts: 198 Gainesville Fl
mphsmitch
Gainesville Fl
For what its worth Ive had both of the Crosswind and the Air Gap intakes on my truck when it had the stock bottom end 360 magnum in it. There was no difference in ET at the track.
90 Dakota 408 CID R/T heads 727 trans 9.5 converter 8.8 rear Pro 275/60 drag radials [email]11.09 @120mph[/email] N/A
[Re: gregsdart]
#2235754
01/17/17 12:37 AM
01/17/17 12:37 AM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
I have a professional products dual plane on my 318 magnum. Works good. Best results so far in my signature. My cam is 231/238@50
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: gregsdart]
#2235776
01/17/17 01:07 AM
01/17/17 01:07 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Not to hijack, but B3442W5 please tell us more about your combo. That et in your sig is impressive!!
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#2235811
01/17/17 02:02 AM
01/17/17 02:02 AM
B3422W5
Portage,michigan
Not to hijack, but B3442W5 please tell us more about your combo. That et in your sig is impressive!! It's an engine masters build. 10.44 compression. Ported magnum Rt heads. 950 carb, aforementioned hydraulic cam. Diamond slugs, scat rods, trick lightened 340 crank. 30 over 318 for 323 cubes. Cheapie 1/5 8 headers, 904, tight 8 inch converter, 28 inch radial with 4.10 gear. Shift it at 6200, traps about 6. Could use a little more gear but I drive it everywhere. All steel car, 310 pound driver. Nice attention to detail on the short block build, several oiling mods, and rocker shaft upgrades. But, she has a dinky cam and not much compression, think there is still more.
[Re: gregsdart]
#2236644
01/18/17 12:47 PM
01/18/17 12:47 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Don't use the stock magnum valve springs, barely good enough for the stock cam, then the two piece valves are at risk...Replace the timing chain too. Maybe you know all this.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: gregsdart]
#2236682
01/18/17 02:03 PM
01/18/17 02:03 PM
Posts: 2,128 sweden
sshemi
sweden
Whatever you do do NOT remove the heads! Youll only find tons of cracks in the valve seats and want to replace them... Dont ask me how i know:-) It sucks as the magnum heads look so much better than la heads. Im positive a very small amount of porting/clean up will make them flow very well. But they all seem to have cracks and throwing time and money on cracked heads is hard to motivate.
[Re: gregsdart]
#2236756
01/18/17 04:04 PM
01/18/17 04:04 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
If cracks make you loose sleep and you are gonna pull the heads have the EQs ready, your heads are cracked. If you have seen thousands of these heads running just fine with cracks in them like I have don't worry about it.
Also I have built tons of these engines with bigger cams than that that see daily use under severe conditions and never seen a stock valve fail except the ocasional burnt valve when nearing 300,000 miles. I am currently running .575 lift and 222@.050 duration 12 to 1 compression in my truck with the stock valves plenty of 6500 RPM blasts and no issues.
