Re: Machinist Needed
[Re: Kelob_pie]
#2228010
01/05/17 06:55 PM
01/05/17 06:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If I was gonna be around I would do it but I'm headed to Texas in a few days and wont be back for 2 months... plus I need a print or a good sketch with diamentions
[Re: Monte_Smith]
#2228191
01/05/17 10:36 PM
01/05/17 10:36 PM
MR_P_BODY
Looks like a funnel. Check the stock at Otterzone, they could get something close for a couple bucks. This is exactly right. For the purpose this serves. Precision machined from alum and sexy looking probably makes it work no better Alum or plastic does the same thing.. bends the upper air downward
[Re: MR_P_BODY]
#2228233
01/05/17 11:07 PM
01/05/17 11:07 PM
Posts: 289 Lowes
steve660
Lowes
You can get Aluminum funnels at Ace Hardware.
I made a similar setup awhile back. Easy to cut down to size using tin snips.
Also used silicone to attach it under the breather lid.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: racerhog]
#2228778
01/06/17 06:18 PM
01/06/17 06:18 PM
RapidRobert
and I would want the lower housing straightened out (from what is in the pic) for less restriction there (fab a new one). I know it has to have some rise to clear the carb linkage but it seems like those "universal" dimentions at least from what I can see in the pic are a waste & are causing a restriction to unobstructed airflow.
