Machinist Needed #2227771
01/05/17 02:20 PM
01/05/17 02:20 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I need a bushing made out of aluminum approx 1-1/8 I'd 2.0 od with a 2-250 flange. I'm say 3/4 to 1 wide. I can get exact specs later just putting out to see if it can be done and how much.
Re: Machinist Needed [Re: Scamp408] #2227838
01/05/17 03:13 PM
01/05/17 03:13 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I have an idea for something relatively small that I'd like machined out of aluminum, too, and was thinking of posting a similar question.
So... let's see who rises to the occasion. grin
Re: Machinist Needed [Re: BradH] #2227870
01/05/17 03:38 PM
01/05/17 03:38 PM
south jersey
474dodge Offline
474dodge  Offline
south jersey
Try Ryans Industrial Machine Shop Phone#732-566-9538 His name is Chris.
Re: Machinist Needed [Re: 474dodge] #2227876
01/05/17 03:48 PM
01/05/17 03:48 PM
Kewaskum, WI
K
Kelob_pie Offline
Kelob_pie  Offline
K
Kewaskum, WI
Hey Guys-
I would be able to do these projects, pretty much for cost of material and couple bucks for beer money.
PM me for more details.
John
Re: Machinist Needed [Re: Kelob_pie] #2228010
01/05/17 06:55 PM
01/05/17 06:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If I was gonna be around I would do it but
I'm headed to Texas in a few days and wont be
back for 2 months... plus I need a print or
a good sketch with diamentions
wave
Re: Machinist Needed [Re: Scamp408] #2228046
01/05/17 07:35 PM
01/05/17 07:35 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Specs tonight. And a pic
Re: Machinist Needed [Re: Scamp408] #2228089
01/05/17 08:40 PM
01/05/17 08:40 PM
BradH Offline
BradH  Offline
What I have in mind is a better design of what Professional Products sells as the AirFlo. I think the concept has merit, but their execution is... less than ideal. puke
Here's pic of "their" approach, and a mock-up drawing (dimensions still needed) of what I have in mind.
Re: Machinist Needed [Re: Scamp408] #2228157
01/05/17 09:58 PM
01/05/17 09:58 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Looks like a funnel. Check the stock at Otterzone, they could get something close for a couple bucks. boogie
Re: Machinist Needed [Re: slantzilla] #2228181
01/05/17 10:31 PM
01/05/17 10:31 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
This is exactly right. For the purpose this serves. Precision machined from alum and sexy looking probably makes it work no better
Re: Machinist Needed [Re: Monte_Smith] #2228191
01/05/17 10:36 PM
01/05/17 10:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Alum or plastic does the same thing.. bends
the upper air downward
wave
Re: Machinist Needed [Re: MR_P_BODY] #2228233
01/05/17 11:07 PM
01/05/17 11:07 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
You can get Aluminum funnels at Ace Hardware.
I made a similar setup awhile back.
Easy to cut down to size using tin snips.
Also used silicone to attach it under the breather lid.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Machinist Needed [Re: Scamp408] #2228247
01/05/17 11:18 PM
01/05/17 11:18 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Use a filtered lid.
Mopar to the bone!!!
Re: Machinist Needed [Re: Scamp408] #2228270
01/05/17 11:37 PM
01/05/17 11:37 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
The bushing. No need for the notches
Re: Machinist Needed [Re: Scamp408] #2228333
01/06/17 12:46 AM
01/06/17 12:46 AM
BradH Offline
BradH  Offline
I believe I've found what I need without having something machined for me, although there will still be a bit if fabrication on my part.
My thanks to those who offered to help with my original request.
Re: Machinist Needed [Re: Scamp408] #2228396
01/06/17 02:23 AM
01/06/17 02:23 AM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Just buy the Moroso Air Cleaner !!!!!
Dam.... hahahahahahahahahahahahaha
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Machinist Needed [Re: racerhog] #2228778
01/06/17 06:18 PM
01/06/17 06:18 PM
and I would want the lower housing straightened out (from what is in the pic) for less restriction there (fab a new one). I know it has to have some rise to clear the carb linkage but it seems like those "universal" dimentions at least from what I can see in the pic are a waste & are causing a restriction to unobstructed airflow.
Re: Machinist Needed [Re: Scamp408] #2233300
01/13/17 02:19 AM
01/13/17 02:19 AM
McKinney, TX
badeeds Offline
badeeds  Offline
McKinney, TX
Scamp408, I could make that for you unless someone else if already doing it for you.
Brian
Re: Machinist Needed [Re: Scamp408] #2233384
01/13/17 08:42 AM
01/13/17 08:42 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I have been in contact with one of the guys on here Thank You.
Re: Machinist Needed [Re: Scamp408] #2235192
01/16/17 11:17 AM
01/16/17 11:17 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I still need 2 of these made I sent pm but they were unanswered unless I messed up on my end.
