Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler
[Re: 65Fury440]
#2225623
01/02/17 03:39 PM
01/02/17 03:39 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I use mine all the time..... Works fine.
The more you use it, the easier it gets.
I've used it to swap roller springs with 240lbs seat pressure.
Depending on how much room you have around the master cylinder, and how well you can get around the hood hinges will determine if you need an assistant for the rear cylinders. It's easy to use if you have good access to everything.
[Re: 65Fury440]
#2225974
01/02/17 11:33 PM
01/02/17 11:33 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
http://www.ebay.com/itm/COMP-Cams-Valve-Spring-Compressor-Steel-Shaft-Mount-Chrysler-383-440-B1-Ea-5324-/331586842522?hash=item4d341daf9a:g:2xsAAOSwMmBVhXLq&item=331586842522&vxp=mtr
Is this VS compressor usable for people not cycling steroids? There is no lock mechanism. Use a cheater bar if you feel the need. I prefer the price of the home made version.
[Re: 65Fury440]
#2226957
01/04/17 08:46 AM
01/04/17 08:46 AM
Posts: 305 CA
David Lee
CA
the only problem with these, its hard to remove springs when the heads are removed
Ah...so many pedestrians, so little time...
[Re: David Lee]
#2226981
01/04/17 10:48 AM
01/04/17 10:48 AM
Posts: 9,858 MI, usa
dvw
MI, usa
the only problem with these, its hard to remove springs when the heads are removed Not if you drill a couple holes in the bench and bolt the head down. I changed my 310lb on the seat this way. Quick and easy. Once I had the spring seat heights measured, 8 springs installed in about 10 minutes. Doug
[Re: 383man]
#2226998
01/04/17 11:40 AM
01/04/17 11:40 AM
Posts: 1,462 Martinsville, IN
cdwmotorsports
Martinsville, IN
383man I don't see that on Mancini's website at all. Got a link?
eBay-cdwmotorsports
[Re: cdwmotorsports]
#2227100
01/04/17 02:33 PM
01/04/17 02:33 PM
Posts: 1,073 oregon
greendart408
oregon
Look no further than lsm, absolute cadillac. Makes changes a no brainer breeze.
[Re: greendart408]
#2227104
01/04/17 02:39 PM
01/04/17 02:39 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
Look no further than lsm, absolute cadillac. Makes changes a no brainer breeze. what Greg said. There is no comparison!!
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: 65Fury440]
#2227221
01/04/17 05:39 PM
01/04/17 05:39 PM
fast68plymouth
So. Burlington, Vt.
Anyone got a pic of the in-car LSM tool that works with the stock style Mopar heads/rocker gear?
Never mind...... I went to their site and checked it out. Looks pretty heavy duty.
$220
[Re: fast68plymouth]
#2227232
01/04/17 05:53 PM
01/04/17 05:53 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought their on head valve spring pressure tool too and it is very nice. Easy to use at the track or at home
[Re: dvw]
#2227359
01/04/17 09:15 PM
01/04/17 09:15 PM
Posts: 305 CA
David Lee
CA
I'll guess i will try that, what stops the valve from following the retainer?
