COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler #2225620
01/02/17 03:36 PM
01/02/17 03:36 PM
Spring Hill Fl
65Fury440 Offline OP
Spring Hill Fl
http://www.ebay.com/itm/COMP-Cams-Valve-Spring-Compressor-Steel-Shaft-Mount-Chrysler-383-440-B1-Ea-5324-/331586842522?hash=item4d341daf9a:g:2xsAAOSwMmBVhXLq&item=331586842522&vxp=mtr
Is this VS compressor usable for people not cycling steroids?
There is no lock mechanism.
Seems like it would make removing retainers a 2 person job.
I have to remove my inner springs for break in, 150lbs on the seat.
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: 65Fury440] #2225623
01/02/17 03:39 PM
01/02/17 03:39 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I use mine all the time..... Works fine.
The more you use it, the easier it gets.
I've used it to swap roller springs with 240lbs seat pressure.
Depending on how much room you have around the master cylinder, and how well you can get around the hood hinges will determine if you need an assistant for the rear cylinders.
It's easy to use if you have good access to everything.
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: 65Fury440] #2225657
01/02/17 04:27 PM
01/02/17 04:27 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
Dang,weren't those like $60 not long ago? Glad I found one at the flea market last year new in the pack for $30.
Works good, not as clumsy as the home made one I've used for years.
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: 65Fury440] #2225951
01/02/17 11:07 PM
01/02/17 11:07 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: 65Fury440] #2225974
01/02/17 11:33 PM
01/02/17 11:33 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Use a cheater bar if you feel the need. I prefer the price of the home made version.
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: 65Fury440] #2226937
01/04/17 06:21 AM
01/04/17 06:21 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I love this tool I got from Mancini's. It so nice as you run the allen head bolt down to push the spring down. And it stays like that so you can use both hands to install and remove valve keepers. Ron
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: 65Fury440] #2226957
01/04/17 08:46 AM
01/04/17 08:46 AM
CA
David Lee Offline
David Lee  Offline
CA
the only problem with these, its hard to remove springs when the heads are removed
Ah...so many pedestrians, so little time...
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: David Lee] #2226981
01/04/17 10:48 AM
01/04/17 10:48 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Not if you drill a couple holes in the bench and bolt the head down. I changed my 310lb on the seat this way. Quick and easy. Once I had the spring seat heights measured, 8 springs installed in about 10 minutes.
Doug
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: 383man] #2226998
01/04/17 11:40 AM
01/04/17 11:40 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
383man I don't see that on Mancini's website at all. Got a link?
eBay-cdwmotorsports
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: cdwmotorsports] #2227100
01/04/17 02:33 PM
01/04/17 02:33 PM
oregon
greendart408 Offline
oregon
Look no further than lsm, absolute cadillac. Makes changes a no brainer breeze.
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: greendart408] #2227104
01/04/17 02:39 PM
01/04/17 02:39 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
iagree what Greg said. There is no comparison!!
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: Old School] #2227140
01/04/17 03:18 PM
01/04/17 03:18 PM
oregon
oregon
up Everyone that has borrowed or seen it has promptly ordered one.
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: greendart408] #2227192
01/04/17 04:45 PM
01/04/17 04:45 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Valve spring removal is kinda one of those jobs that no single tool can handle both on and off the engine well. I have these plus a few modified ones laying around.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: 65Fury440] #2227218
01/04/17 05:32 PM
01/04/17 05:32 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
If you are going to spend $, buy an LSM as mentioned.
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: 65Fury440] #2227221
01/04/17 05:39 PM
01/04/17 05:39 PM
So. Burlington, Vt.
So. Burlington, Vt.
Anyone got a pic of the in-car LSM tool that works with the stock style Mopar heads/rocker gear?
Never mind...... I went to their site and checked it out.
Looks pretty heavy duty.
$220
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: fast68plymouth] #2227232
01/04/17 05:53 PM
01/04/17 05:53 PM
PA.
"Little"John
"Little"John
PA.
I bought their on head valve spring pressure tool too and it is very nice. Easy to use at the track or at home
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: 65Fury440] #2227326
01/04/17 08:30 PM
01/04/17 08:30 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
I used one for the Jesel setup. It made changing springs an easy, one person job.
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: dvw] #2227359
01/04/17 09:15 PM
01/04/17 09:15 PM
CA
David Lee Offline
David Lee  Offline
CA
I'll guess i will try that, what stops the valve from following the retainer?
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: 65Fury440] #2227381
01/04/17 09:53 PM
01/04/17 09:53 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
100 psi of air pressure through the spark plug hole, usually...
Re: COMP Cams Valve Spring Compressor Steel Shaft Mount Chrysler [Re: 65Fury440] #2227394
01/04/17 10:14 PM
01/04/17 10:14 PM
western PA
stevet340 Offline
stevet340  Offline
western PA
the LSM stuff is nice, but the Buxton engineering stuff is way nicer! It is the very best, the absolute Caddilac of valve spring compressors! Buxtonengineering.com look up the video on Youtube and see for yourself, here is the link. https://youtu.be/hs7APpOx2Yo
