Oiling system for 8000+ RPM B-block
#2215593
12/17/16 01:13 PM
12/17/16 01:13 PM
Posts: 248 near St Petersburg, FL
Lifsgrt
I plan to use a Milodon road race oil pan on with wedge. No room for a dry sump setup, so planning a dual external line Milodon pump, so would have to modify the pan for dual pickups. Any recommendations on keeping this engine properly oiled? The B1 heads drain through external lines to the pan. Windage tray recommendation? Should I block oil in the middle of the lifter valley and route to the back and front of the valley? Thanks for your help, I cannot afford to learn the mistakes on my own!
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Oiling system for 8000+ RPM B-block
[Re: Lifsgrt]
#2215636
12/17/16 02:12 PM
12/17/16 02:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm sure Al will see this and help you out... but he runs aftermarket blocks to make them live and priority oiling is a start.. and a dry sump is another.. being that your playing on the salt and will be at high rpm for minutes you WILL suck a wet sump dry.. you better rethink your engine
[Re: EchoSixMike]
#2215749
12/17/16 04:47 PM
12/17/16 04:47 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Crank scraper as well. Also external booster oil supply like an accusump would be wise. B1 head oil return is a PITA. S/F....Ken M Full groove main bearings, loose, not tight , bearing clearances,.003+ on both the rods and mains and plenty of oil in the pan set the bypass spring for .0010 per each thousand RPM with warm or hot oil
[Re: Lifsgrt]
#2215784
12/17/16 05:35 PM
12/17/16 05:35 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
Do all the tricks you can to get the oil back to the pan, use a full synthetic oil, tends to slide off those surfaces better, grind all the little ridges off, chamfer all drain back holes, over fill the pan as much as it will allow, once it gets up to rpm there will be a lot of oil up there but still have some in reserve in pan. Once you learn that curve the windage can be sorted out. Good luck
[Re: Lifsgrt]
#2215802
12/17/16 06:09 PM
12/17/16 06:09 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Razor/ Missile enterprises dry sump. Make room.
[Re: Lifsgrt]
#2215804
12/17/16 06:10 PM
12/17/16 06:10 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Look at the fittings that go through the pan to the pickup, and make sure they aren't intruding on the available space for oil flow into the fitting from the pan. I had to cut off the AN tapered male seat on mine, and then bevel the entry for the best setup. You might want to consider an accusump as well.
[Re: TRENDZ]
#2215864
12/17/16 08:24 PM
12/17/16 08:24 PM
MR_P_BODY
Razor/ Missile enterprises dry sump. Make room. Thats my opinion on this.. I dont know of any pan that will hold enough oil for a few minutes of WOT.. most guys complain about the low oil when they hit the brakes on the top end.. thats in 9-10 seconds on a BB
[Re: Lifsgrt]
#2217275
12/19/16 09:50 PM
12/19/16 09:50 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Use an oil shedding compound inside the lifter valley and in the crank area like glyptol or some of the new ceramic stuff, that helps the oil get back to the pan. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Stanton]
#2217431
12/20/16 01:14 AM
12/20/16 01:14 AM
Posts: 1,113 Usa
A39Coronet
Usa
I remember seeing a photo of the valley of Dave Dudek's FAST hemi and all the holes down the center were closed up so the oil would only drain back at the front. This would keep the oil in a steady stream and ever though it would still get beat up by the front two rods, it would be a heavier/faster flow back to the pan. Seems counterproductive when you consider G force sending the oil backwards away from the opening at the distributor gear area. Make sure you doctor up those Milodon fittings to radius the 90s. I wasn't impressed with the quality of their kits, perticularly the fittings exiting the oil pan. I'd either replace them with full flow 90 ANs or hog them out to take out the corner. Also, if you're going to use the Glyptal paint, I'd suggest using EL601 Red Insulating Varnish spray can. It's $5 a can vs. Eastwood's $50 can and works just as well.
[Re: A39Coronet]
#2217995
12/20/16 09:33 PM
12/20/16 09:33 PM
RapidRobert
[Also, if you're going to use the Glyptal paint, I'd suggest using EL601 Red Insulating Varnish spray can. It's $5 a can A39Coronet is that EL601 number also a Glyptal brand?
[Re: RapidRobert]
#2218018
12/20/16 10:02 PM
12/20/16 10:02 PM
dogdays
