Max Wedge Intake - Valve Covers #2213791
12/14/16 11:16 AM
12/14/16 11:16 AM
Nashville, Tennessee
Tempest Offline OP
Tempest  Offline OP
Anyone know if there are any clearance issues with the repro 440 Max Wedge intakes and the tall Mopar Performance cast valve covers?
Re: Max Wedge Intake - Valve Covers [Re: Tempest] #2213804
12/14/16 11:40 AM
12/14/16 11:40 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I know if you radius the bottom of the carb mounting bases (1/2" radius below the outer carb stud) that the cast Indy covers will come off with a stock Max Wedge intake.
Doug
Re: Max Wedge Intake - Valve Covers [Re: Tempest] #2213918
12/14/16 03:49 PM
12/14/16 03:49 PM
Which Mopar brand valve covers, the chrome steel or the cast aluminum ones shruggy The chrome steel work fine up Maybe the cast aluminum ones also, I can't remember if I ever used them on any of my stock M.W. cross ram motors now confused
Re: Max Wedge Intake - Valve Covers [Re: Tempest] #2213953
12/14/16 05:05 PM
12/14/16 05:05 PM
AndyF Online content
AndyF  Online Content
Yes there is a problem. You'll have to grind or machine the bottom the intake a little bit. Look at the Max Wedge article in the tech archives, I think I had a picture in there that shows the issue.
Re: Max Wedge Intake - Valve Covers [Re: AndyF] #2213972
12/14/16 05:52 PM
12/14/16 05:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
http://www.moparts.org/Tech/Archive/bb/80inches.html
Don't be the exception.
