Grinding or sanding #3 bearing sides? #2207666
12/04/16 05:12 PM
12/04/16 05:12 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Putting together a 484 hemi and have insufficient crankshaft end play. Anybody every grind or sand the number 3 crank bearing to increase end play clearance. Using a new Ohio crank and checks about .002 play when torqued.
Re: Grinding or sanding #3 bearing sides? [Re: maximus] #2207675
12/04/16 05:29 PM
12/04/16 05:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Did you smack the crank back and forth with a
dead blow hammer to set the bearings before you
torque the caps
wave
Re: Grinding or sanding #3 bearing sides? [Re: maximus] #2207703
12/04/16 06:18 PM
12/04/16 06:18 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Yes all the time.
Get some fine grit paper on flat surface.
Normally it's just some high spots from manufacturer.
Re: Grinding or sanding #3 bearing sides? [Re: maximus] #2207768
12/04/16 08:54 PM
12/04/16 08:54 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Ive used wet dry 600 or 1000 grit paper with oil. Make sure the surface is true. never had a problem
Re: Grinding or sanding #3 bearing sides? [Re: maximus] #2207792
12/04/16 09:31 PM
12/04/16 09:31 PM
BPE Offline
BPE  Offline
Very common practice.
Rod
Re: Grinding or sanding #3 bearing sides? [Re: maximus] #2208249
12/05/16 06:27 PM
12/05/16 06:27 PM
organ
maximum entropy Offline
organ
i'm with mr. p-body on this. i bet the bearing needs to be seated. i have NEVER had to increase thrust bearing clearance... that i remember.
Re: Grinding or sanding #3 bearing sides? [Re: maximus] #2208255
12/05/16 06:34 PM
12/05/16 06:34 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Kinda how its done most of the time...
Re: Grinding or sanding #3 bearing sides? [Re: maximus] #2208296
12/05/16 07:48 PM
12/05/16 07:48 PM
crabman173
crabman173
Build enough and sooner or later you have to do a set that way I make sure and use a super flat surface
Re: Grinding or sanding #3 bearing sides? [Re: maximus] #2208428
12/05/16 11:20 PM
12/05/16 11:20 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Broken plate glass mirror and fine lapping compound, make figure-8s.
Boffin Emeritus
Re: Grinding or sanding #3 bearing sides? [Re: maximus] #2208471
12/06/16 12:31 AM
12/06/16 12:31 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
We have to sand them all time. Common practice
Re: Grinding or sanding #3 bearing sides? [Re: maximus] #2208499
12/06/16 01:22 AM
12/06/16 01:22 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I put a sheet of sand paper on my garage window, sand away.
Doug
Re: Grinding or sanding #3 bearing sides? [Re: maximus] #2208566
12/06/16 03:05 AM
12/06/16 03:05 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Sand the front side, not the thrust side.
Re: Grinding or sanding #3 bearing sides? [Re: dthemi] #2208570
12/06/16 03:09 AM
12/06/16 03:09 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
This
Re: Grinding or sanding #3 bearing sides? [Re: MR_P_BODY] #2208571
12/06/16 03:09 AM
12/06/16 03:09 AM
torque the caps
wave
iagree scope thumbs
