Viper Tremec 6 speed hp capability #2207377
12/04/16 02:34 AM
12/04/16 02:34 AM
near St Petersburg, FL
Lifsgrt Offline OP
Lifsgrt  Offline OP
Anybody have experience putting over 900hp through a Viper 6 Speed transmission in a roadrace or Bonneville Salt Flats type environment? I believe it is an -1806, one of the later Viper transmissions. Thanks
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Viper Tremec 6 speed hp capability [Re: Lifsgrt] #2207411
12/04/16 05:07 AM
12/04/16 05:07 AM
Cab_Burge Online work
Cab_Burge  Online Work
Plenty of Viper road racers out there shruggy I'm sure the Silver State road race has had more than one Viper entered that made over 900 HP with the supercharger and EFI conversions available for them, that race is right at 100 mile long on a public highway in central Nevada scope work
Re: Viper Tremec 6 speed hp capability [Re: Lifsgrt] #2207468
12/04/16 11:25 AM
12/04/16 11:25 AM
E
earlymopar Offline
earlymopar  Offline
E
There are a variety of performance parts and mods available for these transmissions so, you are of course not limited to a purely production T-56.
- EM
Re: Viper Tremec 6 speed hp capability [Re: Lifsgrt] #2207473
12/04/16 11:37 AM
12/04/16 11:37 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The Hellcat cars come with a viper spec T56 if I remember right. Dumping the clutch on 4400lbs with that kind of torque can't be easy on them, they seem to hold up.
68 Barracuda Formula S 340
Re: Viper Tremec 6 speed hp capability [Re: Lifsgrt] #2207672
12/04/16 05:21 PM
12/04/16 05:21 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
The later model 6 speeds are a tr-6060. There are differences between the t56 and the 6060, with the 6060 being stronger. I don't think they switched to the 6060 in the viper until 2009 or so. Earlier transmissions can be updated to handle more power. References I have seen are t56 transzilla and donato engineering (google) that have good info. The high power models have 9310 material gearsets and some are modified for external pumps/coolers. There is also a good write up from one of the LS websites that I will link once I find it - even though it doesn't mention the viper specifically, it does have a lot of detail that is good to know. Here is one modified for a cooler with an updated gear set (the two grooves on the input are supposed to indicate the updated gears)
Re: Viper Tremec 6 speed hp capability [Re: Lifsgrt] #2207866
12/04/16 11:31 PM
12/04/16 11:31 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
It depends on what you are using it for. If it's a street car that never sees the track I wouldn't worry about recommended torque specs because you will never really hook it up to stress things. Buddy has a 35 Plymouth with a blown, aluminum, 1100 hp 572 hemi with a tremec 5 spd. Drives it everywhere and took it on PowerTour, No issues.
Re: Viper Tremec 6 speed hp capability [Re: Lifsgrt] #2207915
12/05/16 12:40 AM
12/05/16 12:40 AM
WI
mopar873 Offline
mopar873  Offline
WI
Coming from the LS-world recently, a real common setup is a "Viperized" T56. Transmissions like this with an upgraded slave cylinder are surviving behind numerous full-weight cars hooking with slicks and running single digits on dragstrips. In my experience, the gear cooler-mods come into play when the cars see mid 9's or faster.
The nice thing about running one of these is that the aftermarket support and variety of parts available is huge. Whatever your application turns out to be, I would highly recommend a Tick Performance aftermarket slave cylinder with a remote bleeder line. It makes life so much easier and it has a huge effect on clean clutch disengagement or powershifting a T56 (if you so desire). High power+ a good clutch + stock hydraulics are a no-go.
If you're going to run a scattershield, go with a Quicktime. The fit and setup is way better than some competitors.
Speaking of Tick Performance, a top shelf rep there is Martin Smallwood. He's one of the go-to guys and has a ton of experience both running the 6 speeds and helping others with setups.
Good luck and have fun
Re: Viper Tremec 6 speed hp capability [Re: Lifsgrt] #2207971
12/05/16 02:10 AM
12/05/16 02:10 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This Tremec 5-speed that I went through is in my buddies 69 Camaro with a 468 bigblock and its been holding up ok for years. He just had some worn linkage as it got stuck in 2 gears. I updated it and installed the performance sycro's with the lining material on them. Ron
Re: Viper Tremec 6 speed hp capability [Re: 383man] #2208558
12/06/16 02:51 AM
12/06/16 02:51 AM
Lifsgrt Offline OP
Lifsgrt  Offline OP
Thanks for the help!
Re: Viper Tremec 6 speed hp capability [Re: Lifsgrt] #2208683
12/06/16 01:28 PM
12/06/16 01:28 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Re: Viper Tremec 6 speed hp capability [Re: Lifsgrt] #2209024
12/06/16 11:16 PM
12/06/16 11:16 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Road race: cooler, and think about one for the diff as well. Doesn't have to be fancy, a $60 12 volt Shur-Flo and a small ATF cooler is a big improvement.
Boffin Emeritus
