Viper Tremec 6 speed hp capability
#2207377
12/04/16 02:34 AM
12/04/16 02:34 AM
Posts: 248 near St Petersburg, FL
Lifsgrt
Anybody have experience putting over 900hp through a Viper 6 Speed transmission in a roadrace or Bonneville Salt Flats type environment? I believe it is an -1806, one of the later Viper transmissions. Thanks
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: Viper Tremec 6 speed hp capability
[Re: Lifsgrt]
#2207473
12/04/16 11:37 AM
12/04/16 11:37 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
The Hellcat cars come with a viper spec T56 if I remember right. Dumping the clutch on 4400lbs with that kind of torque can't be easy on them, they seem to hold up.
68 Barracuda Formula S 340
[Re: Lifsgrt]
#2207672
12/04/16 05:21 PM
12/04/16 05:21 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
The later model 6 speeds are a tr-6060. There are differences between the t56 and the 6060, with the 6060 being stronger. I don't think they switched to the 6060 in the viper until 2009 or so. Earlier transmissions can be updated to handle more power. References I have seen are t56 transzilla and donato engineering (google) that have good info. The high power models have 9310 material gearsets and some are modified for external pumps/coolers. There is also a good write up from one of the LS websites that I will link once I find it - even though it doesn't mention the viper specifically, it does have a lot of detail that is good to know. Here is one modified for a cooler with an updated gear set (the two grooves on the input are supposed to indicate the updated gears)
[Re: Lifsgrt]
#2209024
12/06/16 11:16 PM
12/06/16 11:16 PM
Posts: 4,209 New York
polyspheric
New York
Road race: cooler, and think about one for the diff as well. Doesn't have to be fancy, a $60 12 volt Shur-Flo and a small ATF cooler is a big improvement.
Boffin Emeritus
