Re: Grinding or sanding #3 bearing sides?
[Re: maximus]
#2207675
12/04/16 05:29 PM
12/04/16 05:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Did you smack the crank back and forth with a dead blow hammer to set the bearings before you torque the caps
[Re: maximus]
#2208249
12/05/16 06:27 PM
12/05/16 06:27 PM
Posts: 5,080 organ
maximum entropy
organ
i'm with mr. p-body on this. i bet the bearing needs to be seated. i have NEVER had to increase thrust bearing clearance... that i remember.
[Re: maximus]
#2208255
12/05/16 06:34 PM
12/05/16 06:34 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Kinda how its done most of the time...
[Re: maximus]
#2208296
12/05/16 07:48 PM
12/05/16 07:48 PM
crabman173
crabman173
Build enough and sooner or later you have to do a set that way I make sure and use a super flat surface
[Re: maximus]
#2208428
12/05/16 11:20 PM
12/05/16 11:20 PM
Posts: 4,213 New York
polyspheric
New York
Broken plate glass mirror and fine lapping compound, make figure-8s.
Boffin Emeritus
[Re: dthemi]
#2208570
12/06/16 03:09 AM
12/06/16 03:09 AM
Posts: 5,763 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Sand the front side, not the thrust side. This
