Epoxy primer Help #2207286
12/03/16 11:38 PM
12/03/16 11:38 PM
NY
Beep Beep Offline OP
NY
Hi Guys,
I have my 69 RR at the blasters. I need some help with which epoxy primer to use. I was going to use the Nason full poxy 491-10 but after reading up on the product I have found that it is a lower line from Dupont. Also they recommend using there Nasson paint with it. Not sure how good that paint quality is. NAPA sells the Nason brand. I want a really good quality product. I also looked at Basf ep 569. Any input would be great. This will be a nut and bolt resto. So I don't mind spending a bit extra.
Re: Epoxy primer Help [Re: Beep Beep] #2207306
12/04/16 12:09 AM
12/04/16 12:09 AM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Omni works great . Its PPG's cheaper line . I've used it for about 6 years.
Re: Epoxy primer Help [Re: FY1TA] #2207313
12/04/16 12:14 AM
12/04/16 12:14 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
My car ended up with PPG DP epoxy primer.
A painter I know really likes the SPI epoxy primer along with their clear coat.
http://www.southernpolyurethanes.com/
Re: Epoxy primer Help [Re: Beep Beep] #2207315
12/04/16 12:20 AM
12/04/16 12:20 AM
Raleigh, NC
Meangreen68 Offline
Meangreen68  Offline
Raleigh, NC
I would contact Southern Polyurethane Inc.
Their epoxy primer is awesome.
It block-sands so nicely.
Re: Epoxy primer Help [Re: Beep Beep] #2207338
12/04/16 12:58 AM
12/04/16 12:58 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Personally I'd go with the PPG DP Epoxy, I've sprayed Dupont 2K and Chroma P, PPG, and Glasurit paint lines over the DP with no issues...the Nason and Omni lines should be avoided, poor quality performing products
Re: Epoxy primer Help [Re: Beep Beep] #2207346
12/04/16 01:25 AM
12/04/16 01:25 AM
NY
NY
Thanks guys for the quick responses. Any part number on the PPG DP. I have the part number for the SPI brand.
Re: Epoxy primer Help [Re: Beep Beep] #2207351
12/04/16 01:34 AM
12/04/16 01:34 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
PPG DP should have a number after it like DP90, DP50, ect. The 90 is black and the 50 is light grey. I believe they also make it in white, light blue, light green, and red. The cost should all be the same
Get the tech sheet and read it before using it. There is a 30 minute agitation period before you can spray it.
Re: Epoxy primer Help [Re: Beep Beep] #2207366
12/04/16 02:03 AM
12/04/16 02:03 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I wouldn't use omni If it was free, pretty low quality
Re: Epoxy primer Help [Re: NANKET] #2207379
12/04/16 02:34 AM
12/04/16 02:34 AM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Ya it looks like cheap sh!t
Re: Epoxy primer Help [Re: Beep Beep] #2207383
12/04/16 02:45 AM
12/04/16 02:45 AM
NY
NY
WOW!
Re: Epoxy primer Help [Re: Beep Beep] #2207384
12/04/16 02:46 AM
12/04/16 02:46 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
It looks great, I typed that it is low quality, meaning the longevity is not as good as a premium product. A good painter with a proper operating spray gun can get most any paint product to look good.
Question is how long will it last? When do you want to do it again?
Re: Epoxy primer Help [Re: NANKET] #2207385
12/04/16 02:49 AM
12/04/16 02:49 AM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
This one was done 14 years ago and still looks the same.
Re: Epoxy primer Help [Re: Beep Beep] #2207420
12/04/16 06:25 AM
12/04/16 06:25 AM
Vancouver, WA
Cuda Cody Offline
Cuda Cody  Offline
Vancouver, WA
I think PPG DP Epoxy line is one of the best on the market. But if you're on a tight budget and want a good Epoxy for cheap find yourself some Commercial Performance Coatings CRE. It's PPG's heavy duty industrial Epoxy. I was told it's a different division of PPG (not automotive) that makes coatings for salt water applications (like sea boats), but they share a lot of the same technology as the Automobile line. And because they don't have the overhead that the Automobile division does they sell the CRE for less. It's about half the price of PPG DP around here. An old PPG rep told me the CRE Epoxy was just the old DP Epoxy formula with Lead still in it, but they have now taken the lead out of it too. Don't use it as a sealer because it's thick like the old DP Epoxy was. And don't think you're going to sand it down very easy. This stuff is like trying to sand a rock. It covers about twice as good any other Epoxy so you'll need to spray faster then you're used to. I use it on bare metal when I want a bullet proof lock to keep rust out. Here's the spec sheet:
http://us.ppgrefinish.com/PPG-Refinish/Products/Commercial-Coatings/Commercial-Performance-Coatings
http://buyat.ppg.com/RefinishProductCata...49-9D6199CD6DCB
But if I was you I would go with the proven PPG DP Epoxy. It's regarded as one of the top automobile Epoxy's on the market and has a great reputation of holding up well long term. I have only been experimenting with the PPG CRE for about a year and it's really impressing me, but I can not tell you for sure 100% that it's as good or better then PPG DP. However, if it was a price issue (as PPG DP is about $400 a gallon with hardener) I would most certainly go with PPG CRE over the cheaper lines of Nason or Omni. I've shot a lot of PPG Omni line for my sign company and it's okay. There's worse out there, but there's also better.
1970 Challenger T/A 4-Speed
1970 Challenger T/A Auto
1970 Challenger R/T Auto
1970 Challenger Auto
1970 Challenger RT 440+6 4-Speed
1970 Hemi Challenger 4-Speed
1970 Hemi Cuda 4-Speed
1971 Cuda Auto
1971 Cuda 4-Speed
LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
Re: Epoxy primer Help [Re: Cuda Cody] #2207453
12/04/16 10:51 AM
12/04/16 10:51 AM
California
1970mopar Offline
1970mopar  Offline
California
I agree with CODY. Either PPG DP line or the industrial line if you are on a budget.
I've used the industrial line for OE restoration work, as the products work great to mimick the finish of the original "DIP" procedure that Chrysler was famous for when doing underbody refinishing.
Re: Epoxy primer Help [Re: Beep Beep] #2207600
12/04/16 03:24 PM
12/04/16 03:24 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Nason has less solids in it.. When spraying it you create a fog of paint that sticks to everything in the shop...
Bottom of my car has it... Would never use it again... Not because of how it turned out but the huge mess it made at the painters...
Re: Epoxy primer Help [Re: Beep Beep] #2207806
12/04/16 10:01 PM
12/04/16 10:01 PM
NY
NY
Thanks guys for all the info. I am going to stick with PPG.
Re: Epoxy primer Help [Re: Beep Beep] #2207809
12/04/16 10:13 PM
12/04/16 10:13 PM
USA
hudsonhornet7x Offline
USA
I have been a bodyman all of my adult life, and now teach the trade. Of all of the epoxy primers I have used, SPI is hands down the best. From adhesion, sandability, work time, etc. SPI is the one to pick. Many, Many pebble beach cars have been done with 100% SPI products.
All this coming from a lifetime DuPont guy, and you know how they are!!!
If you have any questions please ask and I will be happy to answer.
Re: Epoxy primer Help [Re: Beep Beep] #2207812
12/04/16 10:22 PM
12/04/16 10:22 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
(I've got some DP-40 under some Standox color...
It was sprayed in 1993...
It's doing real well...
Re: Epoxy primer Help [Re: RSNOMO] #2207841
12/04/16 11:09 PM
12/04/16 11:09 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Was a different formula in 1993. Current product is lead free. I liked the old stuff but haven't used the new. I have heard from more than a few that the new LF is not as good. I personally like the SPI.
Re: Epoxy primer Help [Re: forphorty] #2207871
12/04/16 11:40 PM
12/04/16 11:40 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Yeah, we know about the 'tweak' of the modern...
The longevity will not be there...
Be it paint, glass, or re-pop parts...
