Epoxy primer Help
#2207286
12/03/16 11:38 PM
12/03/16 11:38 PM
Posts: 749 NY
Beep Beep
NY
Hi Guys,
I have my 69 RR at the blasters. I need some help with which epoxy primer to use. I was going to use the Nason full poxy 491-10 but after reading up on the product I have found that it is a lower line from Dupont. Also they recommend using there Nasson paint with it. Not sure how good that paint quality is. NAPA sells the Nason brand. I want a really good quality product. I also looked at Basf ep 569. Any input would be great. This will be a nut and bolt resto. So I don't mind spending a bit extra.
Re: Epoxy primer Help
[Re: Beep Beep]
#2207383
12/04/16 02:45 AM
12/04/16 02:45 AM
Posts: 749 NY
Beep Beep
NY
[Re: NANKET]
#2207385
12/04/16 02:49 AM
12/04/16 02:49 AM
Posts: 1,890 In the 8's
FY1TA
In the 8's
This one was done 14 years ago and still looks the same.
[Re: Beep Beep]
#2207420
12/04/16 06:25 AM
12/04/16 06:25 AM
Posts: 765 Vancouver, WA
Cuda Cody
Vancouver, WA
I think PPG DP Epoxy line is one of the best on the market. But if you're on a tight budget and want a good Epoxy for cheap find yourself some Commercial Performance Coatings CRE. It's PPG's heavy duty industrial Epoxy. I was told it's a different division of PPG (not automotive) that makes coatings for salt water applications (like sea boats), but they share a lot of the same technology as the Automobile line. And because they don't have the overhead that the Automobile division does they sell the CRE for less. It's about half the price of PPG DP around here. An old PPG rep told me the CRE Epoxy was just the old DP Epoxy formula with Lead still in it, but they have now taken the lead out of it too. Don't use it as a sealer because it's thick like the old DP Epoxy was. And don't think you're going to sand it down very easy. This stuff is like trying to sand a rock. It covers about twice as good any other Epoxy so you'll need to spray faster then you're used to. I use it on bare metal when I want a bullet proof lock to keep rust out. Here's the spec sheet: http://us.ppgrefinish.com/PPG-Refinish/Products/Commercial-Coatings/Commercial-Performance-Coatingshttp://buyat.ppg.com/RefinishProductCata...49-9D6199CD6DCBBut if I was you I would go with the proven PPG DP Epoxy. It's regarded as one of the top automobile Epoxy's on the market and has a great reputation of holding up well long term. I have only been experimenting with the PPG CRE for about a year and it's really impressing me, but I can not tell you for sure 100% that it's as good or better then PPG DP. However, if it was a price issue (as PPG DP is about $400 a gallon with hardener) I would most certainly go with PPG CRE over the cheaper lines of Nason or Omni. I've shot a lot of PPG Omni line for my sign company and it's okay. There's worse out there, but there's also better.
1970 Challenger T/A 4-Speed 1970 Challenger T/A 4-Speed 1970 Challenger T/A Auto 1970 Challenger R/T Auto 1970 Challenger Auto 1970 Challenger RT 440+6 4-Speed 1970 Challenger RT 440+6 4-Speed 1970 Hemi Challenger 4-Speed 1970 Hemi Cuda 4-Speed 1971 Cuda Auto 1971 Cuda 4-Speed LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
[Re: Beep Beep]
#2207600
12/04/16 03:24 PM
12/04/16 03:24 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
Nason has less solids in it.. When spraying it you create a fog of paint that sticks to everything in the shop...
Bottom of my car has it... Would never use it again... Not because of how it turned out but the huge mess it made at the painters...
[Re: Beep Beep]
#2207812
12/04/16 10:22 PM
12/04/16 10:22 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Thanks guys for all the info. I am going to stick with PPG. (I've got some DP-40 under some Standox color... It was sprayed in 1993... It's doing real well...
[Re: RSNOMO]
#2207841
12/04/16 11:09 PM
12/04/16 11:09 PM
Posts: 1,456 oklahoma
forphorty
oklahoma
Thanks guys for all the info. I am going to stick with PPG. (I've got some DP-40 under some Standox color... It was sprayed in 1993... It's doing real well... Was a different formula in 1993. Current product is lead free. I liked the old stuff but haven't used the new. I have heard from more than a few that the new LF is not as good. I personally like the SPI.
